Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Will it fit?? SAPPHIRE 100259L Radeon HD 4870 512MB
Forum Graphic & Displays : Graphics Cards - Will it fit?? SAPPHIRE 100259L Radeon HD 4870 512MB
http://www.jayceooi.com/wp-content/uploads/2008/11/sapphire_hd4870_04.jpg
im building a new system and considering a mid atx case....any1 else have a mid size case with this card??? do u have to pull it out to take out hd's ram etc? i heard some1 on newegg complaining about the size and it has me confused now on whether i should get a mid or full tower
------------------------------ check out some of my work at mypspace.com/konchus
Sponsored Links
It will take up a lotta space and it will be cramped and depending on case and drive position there is a good chance your gonna have to remove it to get to hard drive. Also we had a issue with getting a connector on it for the power it was a extremely tight fit over all and not recommended if you can help it but its doable and ever case is different. Give you a idea of size it takes a good chunk of room up in my Thermaltake Armor case and thats a full size tower. I would recomend a full tower case
------------------------------ http://valid.canardpc.com/cache/banner/514150.png
Reply to HotRoderX
There are 1178 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
