just completed my first ever build, much of it new but not all of it, and it looks like this:
antec 900 mk.2
psu - tagan BZ900w
cpu - amd 7750 black
ram - 4gb ddr2 ocz reaper 800mhz
hsf - ocz vendetta 2
mobo - asus m3a79-t deluxe
gpu - asus HD 4850
monitor - samsung syncmaster 22"
hdds - two WD caviar blacks 640gb in RAID 0
os - vista 64bit
I chucked it all together, and it powered on fine, it posted, i installed vista and voila I'm typing this post on it right now. however, something doesnt seem right.
When I try to play Trials 2 (by redlynx) it tells me, ahem:
"your graphics card is missing critical features... you need directx 9 compatible graphics adapter with pixel shader 2.0 support."
Seeing as I religiously played this game on my older machine, I'm fairly confident this one should run it. Yet i cant get it to open because of this error. I installed the latest directx 9.0c update from windows update, but it made no difference.
So i thought, mebbe its just this game, I'll try TF2. That loads up the valve splash screen, then goes black, and 'crashes' back to desktop. I used the inverted commas, because the machine doesnt crash, its as though its just minimized, but the game is gone and wont load.
It popped up a lack of memory warning once or twice, which I dont get, as I have 4gb, and my paging file is set to 10gb. surely 14gb combined is enough!!!!
I have also installed the latest catalyst driver from ATi, yet that seems to ahve made no difference.
Could anyone suggest a possbile solution to look into? I assumed the pc hadn't recognised the gfx card properly, but its got the latest drivers and hardware monitor states it as "working properly". Any advice would be greatly appreciated as I'm all out of ideas.
(oh, one last thing, internet explorere had a few tantrums, wouldn't let me sign into Tom's, and it won't let me save any favourites either!)
antec 900 mk.2
psu - tagan BZ900w
gpu - asus HD 4850
os - vista 64bit
