Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Power Requirement in Mobo Instructions?- HELP!
Forum Motherboards & Memory : General Motherboard - Power Requirement in Mobo Instructions?- HELP!
Hi,
I'm building a system using a Gigabyte motherboard, and I'm recieving conflicting info regarding how many watts I need to power it. One reviewed on Newegg stated that the mobo “wouldn’t boot” because his PSU was not 500W. He pointed out that on pg 22 in the mobo manual is says…
“To meet expansion requirements, it is recommended that a power supply that can withstand
high power consumption be used (500W or greater). If a power supply is used that does not
provide the required power, the result can lead to an unstable or unbootable system.”
Then he said that he got a 500W PSU and the system still didn’t boot. Obviously it was a problem with the mobo in his case.
My planned system includes…
1. E8500 (will not overclock, at least initially)
2. 4GB DDR2
3. 9600GT
4. DVD Burner
5. (1) One SATA HDD @ 7200RPM
6. (3) 120mm internal fans
7. Zalman CPU Cooler (with 92mm fan)
I used the Newegg power supply calculator and another calculator and they came out to 311W and 286W respectively. Also, from reading reviews of higher performing systems, some users use less potent PSU’s. My common sense says that I’m in the clear.
Scenario 1 is that I get a combo with an Antec 300 case and a Rosewill 430W PSU is $80. Scenario 2 is that I get a combo with the Antec 300 case and an Antec 500W PSU for $110. Both satisfy the 18A requirement for the 9600GT on the +12V rail. Scenario 1 is $30 cheaper.
I want to be confident that the 430W PSU will be sufficient if I get it. What do you think?
Jeff
Message edited by Jeff9 on 07-04-2009 at 02:39:31 AM
Sponsored Links
To me, the extra money would be worth it just to avoid an entry-level Rosewill psu.
I'd feel much better about a build that includes an Antec Earthwatts, eg. , regardless of 430W or 500W. Isn't there a combo - or a "comes with" - that includes an Antec psu?
Isn;t this one OK?
http://www.newegg.com/Product/Prod [...] 6811129065
Reply to Twoboxer
- 0 +
The Rosewill one had decent reviews: 5 eggs. The only problem with the Antec case/PSU you indicated is that it doesn't mention the amperage on the +12V rails. Assuming that the combo comes with a 430W Antec Earthwatts PSU, it only has 17A on the +12V rails, not 18A.
Going back to the original question, since it applies to both the Rosewill and Antec PSU's, will 430W cut it?
Jeff
Reply to Jeff9
Newegg reviews are great, read them all the time, tells me things reviewers often won't or don't. Among the several pitfalls of those reviews is this: the folks who come *here* with PCs that don't boot or freeze in games usually don't go back to Newegg and post (new) reviews. Their "5-egg", "I'm happy with my current 3-day old purchase" still stands.
Advice done. Your question answered narrowly and specifically, as you want it: You are asking about these two sentences:
"To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
They do NOT mean that a psu less than 500W will NOT work. Read the two sentences separately. Even without the words "To meet expansion requirements" they are NOT saying <500W will fail.
Any psu that delivers quality power meeting the installed component requirements over the intended period of use will work. By your calcs, a quality 380W could also work for the exact configuration you list.
Reply to Twoboxer
- 0 +
I appreciate your advice. It makes sense that many satisfied customers do not bother posting a review whereas customers who want to vent about a poor experience want to. Bias to say the least.
Regarding my original question, I wanted to get feedback about the statement from the Gibabyte manual since this is my first build. I appreciate your insight and will probably take advantage of the Antec 300/Antec PSU combo you posted.
One last concern...Many reviews for the 430W Antec unit (which has 17A on 2 +12V rails) cite systems using cards like the 9800GT which have higher amp requirements. Can I assume that a 9600GT will work fine even though the Antec unit falls short of its requirement my 1 amp?
Thanks!
Reply to Jeff9
Yes, it should work fine. I've looked at three GTX cards, didn't find yours (one requiring 18V on one rail), those that I saw wanted 400W+ psu's with ~27W @12V total.
Reply to Twoboxer
- 0 +
A 9600GT only needs about 5 amps; a 9800GT, about 10 amps. A 430 watt Antec Earthwatts PSU would power either one of them (and the rest of the computer, too :)) nicely.
The Earthwatts are pretty good PSU's, but stay away from the Antec Basiq models. And none of the regulars here like the Rosewill PSU's.
Some of the Rosewill cases are reportedly pretty good but the PSU's seem to be one step above junk.
Reply to jsc
- 0 +
OK that makes sense. I'll be going with the Antec300/Antec Earthwatts PSU combo. I appreciate the advice that both of you were able to give me.
Thanks,
Jeff
Reply to Jeff9
Have fun with the build, Jeff. Hope we don't hear from you for a while :)
Reply to Twoboxer
There are 1198 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
