I have a problem in populating ram with s5000xvn intel motherboard: when I use ranks a2, b2, c2, d2 -> ram chipset goes in single channel mode instead of quad (seen with benchs and everest) and I don't see why. I have followed instructions in motherboard documentation, populating slots with identical pairs on a1+b1 then c1+d1, next a2+b2, and c2+d2.
And there is no way:since a pair is in a2+b2 or a2+b2 & c2+d2, chipset goes in single mode.
Rams I have bought are 6x modules of 4gb ddr2 sold by pairs:
- 1 pair bought 6 months ago (kingston/quimonda kvr667d2d4f5k2/8g 5-5-5-15 / 20-43-3-5-3-3),
- 2 pairs bought a few days (kingston/elpida kvr667d2d4f5k2/8g 5-5-5-15 / 20-43-3-5-3-3)
(These rams are not reference tested by intel for this motherboard, but they work all fine, just this pb with channel mode with more than 4 slots busy).
Tests I have done:
a1&b1: quimonda + c1&d1: elpida -> quad channel / a1&b1: elpida + c1&d1: quimonda -> quad channel
a1&b1: quimonda + c1&d1: elpida + a2&b2: elpida -> single channel / a1&b1: elpida + c1&d1: quimonda + a2&b2: elpida -> single channel
a1&b1: quimonda + c1&d1: elpida + a2&b2: elpida + c2&d2: previous old rams -> single channel / a1&b1: elpida + c1&d1: quimonda + a2&b2: elpida + c2&d2: previous old rams -> single channel
EDIT: this is my config, I have tried to search pb over the net without success. I have tried intel support too, and for the moment their response is that ram I use was not tested by intel... + a link to a doc which doesn't help me more than doc I have already read...
Propriétés du processeur:
Type de processeur 2x DualCore Intel Xeon 5130, 2000 MHz (6 x 333)
Alias du processeur Woodcrest
Stepping du processeur B2
Jeu d'instructions x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Vitesse d'horloge originelle 2000 MHz
Min / Max du multiplicateur du CPU 6x / 6x
Multi CPU:
CPU #1 Intel(R) Xeon(R) CPU 5130 @ 2.00GHz, 1995 MHz
CPU #2 Intel(R) Xeon(R) CPU 5130 @ 2.00GHz, 1995 MHz
CPU #3 Intel(R) Xeon(R) CPU 5130 @ 2.00GHz, 1995 MHz
CPU #4 Intel(R) Xeon(R) CPU 5130 @ 2.00GHz, 1995 MHz
Informations physiques:
Forme du composant 771 Contact LGA
Fabricant du processeur:
Nom de l'entreprise Intel Corporation
(CPUID) Propriétés:
(CPUID) Fabricant GenuineIntel
(CPUID) Nom du processeur Intel(R) Xeon(R) CPU 5130 @ 2.00GHz
(CPUID) Révision 000006F6h
(IA) Identifiant de la marque 00h (Inconnu)
Identifiant de la plate-forme 28h / MC 04h (LGA771 DP)
Révision du Microcode Update CD
Unités HTT / CMP 0 / 2
Température Tjmax 80 °C (176 °F)
--------[ Carte mère ]--------------------------------------------------------------------------------------------------
Propriétés de la carte mère:
Identifiant de la carte mère 63-0100-000001-00101111-092308-Chipset$0AAAA000_BIOS DATE: 09/23/08 12:19:37 VER: 08.00.10
Nom de la carte mère Intel Vernonia S5000XVN
Propriétés du bus principal:
Type du bus Intel AGTL+
Largeur du bus 64 bits
Horloge réelle 333 MHz (QDR)
Horloge effective 1333 MHz
Bande passante 10667 Mo/s
Propriétés du bus mémoire:
Type du bus Quad DDR2 SDRAM
Largeur du bus 256 bits
Ratio DRAM:FSB 1:1
Horloge réelle 333 MHz (DDR)
Horloge effective 667 MHz
Bande passante 21333 Mo/s
Informations physiques sur la carte mère:
Sockets/slots processeur 2 LGA771
Slots d'expansion 2 PCI-E x8, 1 PCI-E x16, 2 PCI-X
Slots RAM 8 FB-DIMM
Périphériques intégrés Audio, Dual LAN
Forme Extended ATX
Chipset de la carte mère i5000X
Mémoire physique:
Total 16357 Mo
Utilisé 4229 Mo
Disponible 12127 Mo
Utilisation 26 %
Zone de swap:
Total 15864 Mo
Utilisé 3477 Mo
Disponible 12386 Mo
Utilisation 22 %
Mémoire virtuelle:
Total 32221 Mo
Utilisé 7707 Mo
Disponible 24514 Mo
Utilisation 24 %
Physical Address Extension (PAE):
Supporté par le système d'exploitation Oui
Supporté par le processeur Oui
Active Oui
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ Channel0-DIMM1: Kingston KINGSTON ]
Propriétés du module mémoire:
Nom du module Kingston KINGSTON
Numéro de série 0918FFFFh (4294907913)
Date de fabrication Semaine 20 / 2009
Taille du module 4 Go (2 ranks, 8 banks)
Type du module FB-DIMM
Type de mémoire DDR2 SDRAM FB-DIMM
Vitesse de mémoire DDR2-667 (333 MHz)
Voltage du module 1.5 V / 1.8 V
Méthode de détection d'erreurs ECC
Taux de rafraîchissement Réduit (7.8 us)
Manufacturier DRAM Elpida
Numéro de série 0118803Dh (1031804929)
Nom du module Qimonda 72T512920EFA3SC
Numéro de série 07027616h (376832519)
Date de fabrication Semaine 32 / 2008
Manufacturier AMD Qimonda
Manufacturier DRAM Qimonda
Numéro de série 0200C42Dh (767819778)
Date de fabrication Semaine 33 / 2008
Propriétés du chipset North Bridge:
North Bridge Intel Greencreek 5000X
Plateforme Intel Glidewell
Vitesses FSB supportées FSB1066, FSB1333
Types de mémoire gérés DDR2-533 SDRAM, DDR2-667 SDRAM
Quantité maximum de mémoire 64 Go
Révision 31
Forme du composant 1432 Pin FC-BGA
My guess is that all 4 channels have to be populated the same to have quad channel mode work. That means either 4 total DIMMs (a1, b1, c1, d1) or 8 total DIMMs (a1, b1, c1, d1, a2, b2, c2, d2). You've only got 6 "new" DIMMs, so you can't setup the 2nd config, and quad-channel mode works fine in your 4-DIMM setup.
Plenty of typos and errors in the Intel manual, btw.
------------------------------e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
You're probably right...
But I tried with 8 dimms (6x4GB + 2x2GB), do you think I could have better results with 4x4GB + 4x2GB (I have this rams in reserve) ? Or does it require 8x4GB ?
