Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power supply compatible with the 7950GT?
Forum Graphic & Displays : Graphics Cards - Power supply compatible with the 7950GT?
Hello to all first of all I do not understand good English then forgiveness if I am a wrong impression then we will start
friend give me 7950GT EXTREEM the question if the POWER supplier will hold talking about THERMAL MASTER 420W WHITH 16AMPER IN 12V then will hold or not?
my pc
cpu:Intel Pentium Doul Core E5200 2.5GHZ@3.3GHZ
MB:Abit I-N73V
RAM:Patriot 6400LL Series 1GBX2 DDR2-800
GPU:NVIDIA 7050 O/B/Soon 7950GT EXTREEM 256DDR3?
HD:Samsung 640GB HD642JJ
Optical Drive:Samsung X22 DVD-RW
POWER SUPLY:Cooler Master 420W
CASSE:Cooler Master Elite 334
HELP?
Message edited by yacovmateo on 03-01-2009 at 07:40:13 PM
Sponsored Links
I don't know if that will work. I would be worried about trying it. 16 Amps is not very many for running a modern system, and I don't know about the quality of the brand Thermal Master. Good luck!
-mcg
Reply to MrCommunistGen
Someone else maybe?
Reply to yacovmateo
Best I could come up with is that it is an older ( ATX 1.3 ) Coolermaster oem that was included with thier cases.
Can't find any real specs, but if it's 420 watts and only 16 amps I wouldn't trust it, even my 305 watt Dell power supply can put up to 22 amps on the 12v
Reply to Delluser1
Then this he will not hold?
what can I do ?
Reply to yacovmateo
Try it, if it doesn't work, upgrade the power supply.
Your system is not going to use alot of power, it's the quality and low 12v output of the psu that makes me leary of it.
Does it even have a 6 pin pcie connector ?
Reply to Delluser1
my friend give me the 6pןn
if the power supply can't hold the pc the computer can be burned
Reply to yacovmateo
There are 1159 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
