Tom's Hardware > Forum > Homebuilt Systems > New System Build > READ before posting about boot problems!
Page:    Previous 1 2 3 Next Bottom Search this thread
"New build won't boot" checklist
This checklist is a compilation of troubleshooting ideas from many forum members. It's very important to actually perform every step in the checklist if you want to effectively troubleshoot your problem.
1. Did you carefully read the motherboard owners manual?
2. Did you plug in the 4/8-pin CPU power connector, located near the CPU? If the motherboard has 8 pins and your PSU only has 4 pins, you can use the 4-pin connector. The 4-pin connector USUALLY goes on the 4 pins located closest to the CPU. If the motherboard has an 8-pin connector with a cover over 4 pins, you can remove the cover and use an 8-pin plug if your power supply has one. Check your motherboard owners manual for more information about the CPU power connector. This is easily the most common new-builder mistake.
3. Did you install the standoffs under the motherboard? Did you place them so that they all align with the screw holes in the motherboard, with no extra standoffs touching the board in the wrong place?
4. Did you verify that the video card is fully seated? (may require more force than a new builder expects.)
5. Did you attach all the required power connectors to the video card? (some need two, some need none, many need one.)
6. Have you tried booting with just one stick of RAM installed? (Try each stick of RAM individually in each RAM slot.) If you can get the system to boot with a single stick of RAM, you should manually set the RAM speed, timings, and voltage to the manufacturers specs in the BIOS before attempting to boot with all sticks of RAM installed.
7. Did you verify that all memory modules are fully inserted? (may require more force than a new builder expects.) It's a good idea to install the RAM on the motherboard before it's in the case.
8. Did you verify in the owners manual that you're using the correct RAM slots? Many i7 motherboards require RAM to be installed in the slots starting with the one further away from the CPU which is the opposite of many dual channel motherboards.
9. Did you remove the plastic guard over the CPU socket? (this actually comes up occasionally.)
10. If using an after market CPU cooler, did you get any thermal paste on the motherboard, CPU socket, or CPU pins? Did you use the smallest amount you could? Here's a couple links that may help:
Benchmark Reviews
Arctic Sliver
11. Is the CPU fan plugged in?
12. If using a stock cooler, was the thermal material on the base of the cooler free of foreign material, and did you remove any protective covering? If the stock cooler has push-pins, did you ensure that all four pins snapped securely into place? (The easiest way to install the push-pins is outside the case sitting on a non-conductive surface like the motherboard box. Read the instructions! The push-pins should be turned the OPPOSITE direction as the arrows.)
13. Are any loose screws laying on the motherboard, or jammed against it? Are there any wires run directly under the motherboard? You should not run wires under the motherboard since the soldered wires on the underside of the motherboard can cut into the insulation on the wires and cause a short. Some cases have space to run wires on the back side of the motherboard tray.
14. Did you ensure you discharged all static electricity before touching any of your components?
15. Did you install the system speaker (if provided) so you can check beep-codes in the manual? A system speaker is NOT the same as normal speakers that plug into the back of the motherboard. A system speaker plugs into a header on the motherboard that's usually located near the front panel connectors. If you case or motherboard didn't come with a system speaker you can buy one here: http://www.cwc-group.com/casp.html
16. Did you read the instructions in the manual on how to properly connect the front panel plugs? (Power switch, power led, reset switch, HD activity led) Polarity does not matter with the power and reset switches. If power or drive activity LED's do not come on, reverse the connections. For troubleshooting purposes, disconnect the reset switch. If it is shorted, the machine either will not POST at all, or it will endlessly reboot.
17. Did you turn on the power supply switch located on the back of the PSU? Is the power plug on a switch? If it is, is the switch turned on? Is there a GFI circuit on the plug-in? If there is, make sure it isn't tripped.
18. Is your CPU supported by the BIOS revision installed on your motherboard? Most motherboards will post a CPU compatibility list on their website.
19. Have you tried resetting the CMOS? The motherboard manual will have instructions for your particular board.
20.If you have integrated video and a video card, try the integrated video port. Resetting the bios, can make it default back to the onboard video.
I also wanted to add some suggestions that user jsc often posts. This is a direct quote from him:
"Pull everything except the CPU and HSF. Boot. You should hear a series of long single beeps indicating memory problems. Silence here indicates, in probable order, a bad PSU, motherboard, or CPU - or a bad installation where something is shorting and shutting down the PSU.
To eliminate the possiblility of a bad installation where something is shorting and shutting down the PSU, you will need to pull the motherboard out of the case and reassemble the components on an insulated surface. This is called "breadboarding" - from the 1920's homebrew radio days. I always breadboard a new or recycled build. It lets me test components before I go through the trouble of installing them in a case.
If you get the long beeps, add a stick of RAM. Boot. The beep pattern should change to one long and two or three short beeps. Silence indicates that the RAM is shorting out the PSU (very rare). Long single beeps indicates that the BIOS does not recognize the presence of the RAM.
If you get the one long and two or three short beeps, test the rest of the RAM. If good, install the video card and any needed power cables and plug in the monitor. If the video card is good, the system should successfully POST (one short beep, usually) and you will see the boot screen and messages.
Note - an inadequate PSU will cause a failure here or any step later.
Note - you do not need drives or a keyboard to successfully POST (generally a single short beep).
If you successfully POST, start plugging in the rest of the components, one at a time. "
Here's a link to jsc's breadboarding thread:
http://www.tomshardware.co.uk/foru [...] _13_0.html
If you make it through the entire checklist without success, Proximon has put together another great thread with a few more ideas here:
http://www.tomshardware.com/forum/ [...] g#t1934282
Message edited by shortstuff_mt on 09-26-2009 at 01:10:28 AM
Sponsored Links
Should absolutely be a sticky. This will save people like us frustration from repeating ourselves over and over, and make us more willing to help folks out.
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
Nice guide. Needs to be stickied for sure!
Reply to lurker87
We are looking to refine it a bit before it gets stickied... get some more input from some of the people that help out alot with trouble posts.
Reply to Proximon
- 0 +
Good checklist. My additional comments:
Re #2 - I see a lot of questions about "My mobo has an 8 pin socket, but my PSU only has a 4 pin plug. Where does it go?" Ans. - The 4 pins closest to the CPU. Second answer - "RTFM".
Re #9 - might want to rethink this a little. It's good advice for most coolers, but I'm not certain it applies to coolers like the Xigmatek.
Re #7 and #11 - I alway recommend installing the CPU, HSF, and the RAM before installing the motherboard in the case. RAM sometimes takes a lot of force to install.
Re #14 - Some cases do not come with a system speaker (Antec 900's, for example).
Re #15 - Polarity does not matter with the power and reset switches. If power or drive activity LED's do not come on, reverse the connections.
Reply to jsc
Updated the checklist.
Reply to shortstuff_mt
- -1 +
Might want to add on there if you think its the PSU or the Case's Power switch doing the paper clip and shorting the jumpers/ green wire to black? Common trick to trouble shoot items.
Reply to kubes
I'm not so sure I buy the "paper clip" trick. That only tells you if the PSU is producing any power at all, it may be able to spin the fan, but not power a system. I don't want to be responsible for people frying their PSU's shorting out the wrong pins.
... or frying their pacemakers :)
It's really getting there now. If you think of someone that can contribute to this post, shoot them a PM :)
Message edited by Proximon on 02-05-2009 at 10:43:02 PM
Reply to Proximon
- 0 +
I agree with Proximon. The problem with the paper clip trick is that all it really proves is that the 12 volt output is capable of powering an extremely minimal load. It doesn't check the 3.3 or 5 volt lines. And it doesn't check the "PowerOK" control signal.
Reply to jsc
I completely agree.
- 0 +
+1 for making this a sticky. Great job guys!
Reply to aevm
- 0 +
Another one that sorta piggy backs off of 16. I've ran into multiple cases where people are plugged into receptacle that is controlled by a switch (many states require you to have one because of building codes). What happens is the switch is turned off meaning no power is coming from the receptacle. Also make sure that if your plugged into a GFI (ground fault interrupter) receptacle, it hasn't been triggered. I've seen some people that are using some bigger psu's will trip the GFI because of the extra load.
In other words check the power outlet.
+1 for sticky!!
Reply to kubes
Yeah good point. We have to remember that some people don't think of the obvious all the time.
Reply to Proximon
- 0 +
Speaking of which... Is the PSu plugged in to the wall? :)
Reply to aevm
- 0 +
Maybe another point to add somewhere around the ram section is to make sure there inserted in the right slots. A lot of people using the x58 boards have been inserting sticks in 2 4 6.
Reply to kubes
11. If the stock cooler has push-pins, did you ensure that all four pins snapped securely into place? (The easiest way to install the push-pins is outside the case sitting on a non-conductive surface like the motherboard box. Read the instructions! The push-pins should be turned the OPPOSITE direction as the arrows.)
I use a roll of packing tape or duct tape to support the motherboard while I am pushing on the pushpins.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
You migt want to add:
"Try clearing the bios, by removing the battery for 30 seconds, if you get no response when turning on the computer."
Reply to evongugg
- 0 +
Excellent article.
Additional things to check:
The paperclip trick on the power switch leads can be used to verify if these lines are shorted (or open). If they are shorted, the usual symptom is the PC will power on for 4-5 seconds, then shut down again.
If the system powers on long enough for LEDs to flash and fans to flicker, then shuts off, this symptom suggests a short-circuit somewhere. This is one reason why disconnecting all non-essential components (even the drives) to try for a POST is useful. Be aware that a disconnected GPU will usually shriek to complain of insufficient power. If your mobo has it, use onboard video for initial testing.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
- 0 +
What about troubleshooting?
In the old days we had more expansion cards so if I had a problem I would pull out the extra expansion cards and try it with just video card and mobo.
I think mobo+ram+cpu is the minimum to get the mobo to POST. Of course the only way to know that it is doing this is that the cpu fan is running. Then add a video card so you can see what it is doing. After that you can plug in the drives.
Reply to cadder
- 0 +
I completely agree - sticky needed. You're right - many of us seem to be answering a lot of the same questions. Nice work.
------------------------------ Antec 900, MSI P7N Diamond, E8400,
4 GB (2 x 2GB) Crucial Ballistix 4-4-4-12, 8800 GTS 512 SLI
Reply to huron
- 0 +
This is a pretty good idea. Never thought about using a roll of duct tape/ect to put under the boart when putting on the heatsink. I'll have to use that idea in the future. (Guess your one of us few that installes the cpu and hs while the mb is out of the case). I'd say that tip however isn't part of this thread. Probally in a how to assemble your computer one. Love the idea though.
Reply to kubes
Shameless bump of my own thread.
- 0 +
LOL, it's OK, it's a very useful thread.
Reply to aevm
I would also like to add that a video card is not needed for a computer to boot. If there is a problem where the system wont even pass the BIOS screen and shuts down right after wards, remove the video card to see if it helps.
Tools for ANY one that builds their own computer.
http://www.alwayslowest.com/AL/ind [...] rt=2952576 - Power supply tester.
http://www.newegg.com/Product/Prod [...] 6819116039 - if you have an Intel 775 system
http://www.newegg.com/Product/Prod [...] 819103195- if you have an AM2 system
http://www.newegg.com/Product/Prod [...] 6820134044 - Memory that will work in ANY DDR2 motherboard
http://www.newegg.com/Product/Prod [...] 6814161011 - PCI (not PCI express) video card. Newegg often has some great prices on open-box PCI video cards as well. Check your local ma-n-pa computer store, I'd be willing to bet that they have a working PCI video card somewhere in the back room for about $10.
Buying all of these components will let you diagnose almost any problem on TONS of different computer systems.
Message edited by ir_efrem on 02-26-2009 at 07:38:57 AM
------------------------------ Don't drink and park, accidents cause people.
Reply to ir_efrem
I think it's time for another bump. I've seen another stream of "my new build won't post" links come up again.
I also wanted to add some suggestions that jsc often posts. This is a direct quote from him:
Message quoted 2 times
Message edited by shortstuff_mt on 03-14-2009 at 05:29:25 PM
- 0 +
Install CD/DVD/Blu-Ray drive LAST... seems to be a common source of problems especially since some people are using IDE drives.
Do not close the case until it has all booted up and you have installed the OS, connected to the net and have run Prime95 or something similar and checked CPU temps. Make sure everything is hunky dory before you close up and put it under your desk or wherever. That way you avoid the frustration of having to open it back up and you know that it WAS okay so any cooling issues that arise later are due to fans being installed the wrong way around or due to your case location not having enough airflow available.
Reply to siggy19
- 0 +
WOW, I don't have anything to add other than WOW....I realize now...I am in the company of folks that REALLY know thier stuff!!! Jack is ALL ears!!! I am humbled!!!!!!
Reply to jack64
Updated jsc's comments above.
- 0 +
Really good list. I'm gotta have this book marked.
------------------------------ Computer Parts List http://www.tomshardware.com/forum/ [...] t#t1912274
System Build Template http://www.tomshardware.com/forum/ [...] 6#t1912340
Reply to MykC
I believe this is my problem, I get no sound as soon as I try any combination of RAM in the slots... Do I need new RAM? How can something so little short the PSU? The CPU fan cage (insulated) ends up touching the RAM heatsink in the first position.
I have the cheap G.SKILL 4Gb RAM on a MSI P45 neo3 board with an Antec earthwatts 380W psu.
Anyone know of a good site to troubleshoot this?
Message edited by gregsteg on 03-21-2009 at 06:26:24 PM
Reply to gregsteg
- 0 +
@gregsteg
Try making your own thread for your question. It will make it much easier on us in trying to help you with your problem.
Thanks!!
Reply to kubes
- 0 +
bump again
Reply to aevm
- 0 +
Something about mobos occasionally needing a bios update to actually support given cpu. Doeesn't happen often but shows up every once and a while.
Reply to kyeana
bump and sticky please!
Reply to replan32
That's a good point. We are very cautious about BIOS flashes around here though.
Reply to Proximon
- 0 +
very understandable ;-)
Reply to kyeana
Reply to evongugg
*nod*
Not a bad addition now that we'll be seeing more 790GX boards.
Reply to Proximon
Added the above and some other suggestions to the original post.
- 0 +
i think its about time for a sticky
Reply to kyeana
It sure would be nice to not have to keep bumping it to the top.
I'll send a PM this time ;)
I'll make it a double with the how to ask thread too.
Reply to Proximon
Previous
1 2 3
There are 412 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
