Tom's Hardware > Forum > CPU & Components > Other Components > Do I have a cooling problem?
Forum CPU & Components : Other Components - Do I have a cooling problem?
Hi guys first of all here are my specs
Windows XP sp3
AMD Athlon 64 X2 5000+
2gb RAM
280gb hd
Nvidia Geforce 8800gt
The problem is that on most games I play my computer crashes to a black screen and I then have to restart.
I have all the latest drivers installed for my graphics card and the card is well within the requirements of the games I play such as oblivion, empire total war, fallout 3 to name a few.
This is getting frustrating, as a gamer this sort of thing is ruining the game play experience.
The only cooling I have in my system is the CPU fan and the fan in the graphics card. I keep the side panel off of the PC to try and maximize the airflow but this is facing a wall so I don't know how effective it is. After playing a few games I have felt the card and it is hot but that happens anyway right? with or without cooling. I suspect cooling is my problem.
So my question is> Do ya think I will need a few fans to keep down the temp of my card? Or do you think it could be another problem? Also, if you do think its my cooling that needs a re-vamp, where should I go and what should I get? I'm in the UK so Newegg is off limits.
Thanks for your time,
Keelan
Sponsored Links
Probably a cooling problem. Get rid of the dust and reapply thermal paste if necessary.
With Rivatuner set the fan to 100% all of the time.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Try pointing a fan to the card with the side off.
Then run the game.
You should have an exhaust fan in the case close to the upper part of the case.
You could add a front case fan.
Reply to evongugg
Update the video BIOS with one that will change the fan speed based on temp from EVGA, XFX, BFG if not already done so.
Another option is to get an aftermarket cooler. TT DuOrb and works just great.
Well if you follow the instructions as written the cooler will NOT contact the GPU on an 8800 GT. The tall studs are too long and the short ones if you use them will distort and probably damage the card if you tighten the nuts.
The solution was to use the short studs and put the plastic washers, that are supposed to be under the nuts, between the studs and video card.
The instructions clearly show these plastic washers on the back side of the card not on the front side, but the front side is where I had to put them.
Reply to evongugg
There are 1078 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
