I will be using the HAF 932 full tower case, gonna try to fit everything inside to make it look nice and neat.
here is a list of parts I will be using: (3/8 ID tubing)
Plus: coolant, clamps, fittings, ect.
I'm thinking of routing the flow this way:
Pump-->Rad-->CPU Block-->GPU Block--->GPU Block -->Res.--> Back to pump
btw, is it a good idea to plit the water route into 2? like this
I'm also considering of putting a small Rad between CPU and GPU blocks, but I don't think there is a place to fit it inside the case. Is it even necessary?
edit: The CPU is i7-930 no OC, the GPU is EVGA GTX 470 in SLi
suggestions or comments are appreciated. This will be my first water cooled system, hopefully I didn't miss anything.
