From the last few days the tomshardware community has helped me a lot to find the ultimate budget pc for me.....Now the fight has come down to the last round...
For the gpu I have decided to get myself a nvidia 9600 series card, but I just can't choose the right one...Help Me....Tell me which one of the following will be perfect for me.....(I look for visual performance. It does'nt matter if the card makes too much noise or if it gets too much hot until and unless it melts...) :
Thanks dude....but is that big difference between the vrams of #1 and #2 gonna make much difference...
No, the ram size won't make much difference for these cards. Larger ram size only really helps at high screen resolutions with high end gpus like the hd4870. I have a 9600GSO and I get 12566 in 3dmark06 with it overclocked.
Also, if your friend does not have a very good power supply, consider the ATI 4670, less power draw than all those card, no external power connection, and also close to the performance of the 9600gso.
