I'm havening a fan sped problem i just replaced my stock fan on my Q9300 with a http://www.newegg.com/Product/Product.aspx?Item=N82E16835200012. The thing is my cpu is actually running hotter allot hotter it went from 45c idle to almost 52 c idle. I think the problem is the fan speed it says 500-3400 rpm +- but every application i use says the fan is only going to like 1000 rpm max , if my cores are running so hot why isnt my system increasing the fan speed.
