GREETINGS Legions! ,
ur Ally needs help!!! REINFORCEMENTS!!!!...........
This is a detailed case study, please review thoroughly,
june 25 09/------------bought a new pc for single user.
specs: >C2D -E7400- 2.8GHZ/3MB/1066FSB(FULL 3YRS WARRANTY)
>DG31PR (FULL 3YRS) http://www.intel.com/products/moth [...] /index.htm >1GB SODIUM KINGSTON DDR2 /800FSB(because corsair was out stock initially)
>half TB SEAGATE SATA 2/16MB Cache (6 partitions @80GB per)
>v-low (new) quality chassis
>CM eXtreme PSU 460Watts
>Samsung DVDRW 22X DL SATA (SH-S223F)
-----------$ 335 paid
Future update:
>>HD4770
>>Replace kingston with corsair XMS 2 1GBX2 @800FSB
Required from rig:
>>GAMING TO ITS XXXXTREME
>>MAXIMUM PERFORMANCE
>>COOL N QUIET
>>GREAT RELIABILITY
>>RUN AT STOCK SPEED, NO OCing!!!
PC Surrounding Envoironment:
>>VERY HOT!
>>Fine PSU
>>LOW qualility chasis with vents but no fan except PSU and CPU.
>>5-7hours of gaming/other(S) daily
>>=====!!!!FREQUENT POWER FAILURES @2TIMES DAILY!!!!==========
>>POWER NOT VERY STEADY (MAY NOT BE 220V ALWAYS --MAY BE LOWER!
>>NO UPS OR STABILIZER USED!!!
PC in PERFORMANCE INITALLY:
XP @32BIT:
PSU>mildly (sometimes more)HOT
CPU & MOBO>mildly Warm (45nm advantage)
HDD>>mildly (or lower)HOT.
>>>>100% CPU idle proccess on idle (mostly 0% CPU usage)
>>>>Fine Gaming
>>>>Fans running at mild speed.
GPU(ON BOARD GMA 3100) >>DX9.0c/128MB Max/10MB used for windows/all OK.
Vista @32BIT:
>>>>95-99% CPU idle proccess on idle (0-5% varry CPU usage)
>>>>Fine Gaming
>>>>Fans running at MORE speed.
GPU detects(ON BOARD GMA 3100) >>DX10/258MB (112 shared) Max/128MB used for windows/All OK.
>Sometimes there are slow shutdowns and overAll vista performance is lower thanXP.
because i 'v'e herd that ASUS are good coolers and performers BUT NEVER DID I HEARED THAT INTEL IS BAD, I VE SEARCHED THE WHOLE GLOBE BUT NO ONE- NO ONE DID RIGHT COMPARISION, THEY SAY INTEL IS INTEL... I SAY "WHY", NO BODY REVIEWS INTEL?
WELL the reason i choose intel because the vendor insisting that intel has better warranty than ASUS but they did not spoke clear about which one is better in performance, they said "we recomend intel... final choise is your's sir" PLS NOTE I BOUHT FROM THE BEST REPUTED DEALER/VENDOR OF MY ENTIRE COUNTRY.
SO WHEN I SPEAK TO GAMMERS hey say: ASUS
My vendor: Intel
Other vendor: Intel sometime ASUS for gaming
guys I AM REALLLLY STRESSED UP N CONFUSED IN THIS PLEASE ADVICE, IS MY CURRENT INTEL IS FINE, OR DO I REALLY NEED TO REPLACE WITH ASUS (FOR DIFRENCE/SOMETHING) IS IT REALLY WORTH IT because i did'nt find any prob with intel... is that ASUS board REALLY WONDERFULL?
--remeber i can't get any board exept intel/ASUS at my location (NO GIGBYTES!)
NOTE: please fellows GIVE ME CONCLUSION (chosse) ONE BOARD ONLY (from above two boards ONLY) WITH REASON(BETTER). Initially coment on boards only i l get ur wonderfull advices once my mind is made on board .
HEARTLY THANKS FOR SERVING UR IMPORTANT TIE ON THE ISSUE, THANKS AGAIN.
Intel makes very good boards (could be manufactured by foxconn, asus, etc). Only reason to go with asus is more bios options, such as memory voltage, cpu fsb, etc. Some newer Intel boards come with these options. Asus also has more bios updates, which may not be necessary. Both are similar for warranty. Intel boards aren't reviewed by performance websites as most don't use them for overclocking.
I Knw my frnd by bios opts u mean OCin, which i am not planing to do, the dg31-pr which i bougt is latest (rev10) with new heatsink design and 45nm support etc and in bios it does show all details (read Only) about temps and voltages, there are options of Graphics and all which are generally required, there is only one thing lacking which is OCin(which i WON'T DO). so dear is is any thing still worth considering to replace with p5kpl-cm as per above and any other criteria.? tell me one thing more my frnd are these boards able to perform for gaming and will they support hd4770 with all current sys specs for GUD gaming? pls review. and finnally advice whether shud i go for replacement or stay intel (pls refer to pc surrounding conditions above etc too).
thanx a ton budy.
