Which power supply is BETTER?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Which power supply is BETTER?
Here are the two I am considering;
APEVIA ATX-CW500WP4 500W ATX Power Supply
http://www.newegg.com/Product/Prod [...] 6817148027
OCZ StealthXStream OCZ500SXS 500W ATX12V / EPS12V Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817341012
They are both 500W so I am trying to figure out what the difference between them is. They are about 5 dollars difference in price. I am new to this, thanks!
Sponsored Links
U should consider neither....both are crap
Instead get the Corsair 400Watt. Much better quality
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
Message edited by Silverion77 on 05-05-2009 at 08:53:51 PM
------------------------------ Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
Oh and do I even need a power supply?
Can I just buy those cases that come with one?
I am the computer for light gaming, school work, and some editing. I will be runing an AMD 2.7 Kuma, 4 gigs ram, undecided on video card (leaning towards 4670 because it is mainly for sims 3 that I will be gaming with and maybe WoW here and there)
Appreciating all input!
Reply to KIMBERLY_from_WISCONSIN
U can but they are not going to be of the best quality. (like the Apevia which is crap)
Ocz is a little better, and Corsair is much better.
Corsair, by all means. Avoid Apevia.
Reply to jsc
also you might want to consider a tri-core processor as WoW can use the third core now.
and a 4770 isn't far off price wise from the 4670 but is far more powerful while using the same amount of energy, or a few watts more.
Reply to Helloworld_98
Where the hell did WoW come from?
We're discussing Power Supplies....
http://www.newegg.com/Product/Prod [...] 6817151040
http://www.newegg.com/Product/Prod [...] 6817702014
http://www.newegg.com/Product/Prod [...] 6817371007
http://www.newegg.com/Product/Prod [...] 6817139003
http://www.newegg.com/Product/Prod [...] 6817703017
For a 4670? dont need high amps so get a quality psu instead of getting a cheap one that you just got cuz it fits the 12v levels.
Message edited by IzzyCraft on 05-05-2009 at 09:55:26 PM
Reply to IzzyCraft
I agree with Silverion on the corsair 400 watt. It should fit your needs and has had good reviews on new egg as well as other review sites. The only cases I've used and seen that are relatively inexpensive if you can find them on sale are the Antec Sonata IIIs. Not top notch power supplies but do great for most normal users and the case is relatively quiet if you turn the fans on low. Best of luck.
Reply to hiroman_77
I was looking at NewEgg E-Mail Promotions and they had this if you are wanting a case with a power supply Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply $89.99 With Promo Code EMCLSLS23. Although this may not be your style, but it does come with a decent power supply.
http://promotions.newegg.com/NEema [...] nding.aspx
------------------------------ Case :Antec SLK 1650B /PC Power&Cooling Silencer 610w /ASUS M3A79-T DeLuxe /AMD 940 PII @3830 1.4625v/Zalman 9700 LED /OCZ Reaper 8500 4x1 @1100 4-5-5-15 /EVGA 260 core 55nm 648/1404/1044 / Creative X-Fi Elite Pro - Logitech Z-5500 /Mon:
Reply to unclefester
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Which power supply is BETTER?
There are 830 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
