Help with first watercooling system for i7 930 and GTX470
  • Heatsinks
  • Intel i7
  • CPUs
  • Overclocking
  • Product
August 15, 2010 12:36:31 AM
I currently have a Gigabyte X58A-UD3R with an Intel i7 930 and a Corsair H50 cooler. These components are installed in a Corsair 800D case. I recently overclocked my processor to 4.2GHz, here are my system settings.
CPU Vcore = 1.2875V (level 2 load line calibration)
CPU clock drive = 800mV
DRAM voltage = 1.680V
QPI voltage = 1.375V
base clock = 200MHz
CPU frequency = 4200MHz (21x multiplier, turbo disabled, HT disabled)
uncore frequency = 3200MHz (16x multiplier)
RAM frequency = 1600MHz (8x multiplier)
RAM timing = 8-8-8-24-2
The BIOS is reporting that the DRAM voltage is 1.648V (although it is set to 1.680V), the CPU Vcore is 1.284V (although it is set to 1.2875), and the +12V rail is 12.365V.
Although I feel comfortable with this overclock, I am not comfortable with the heat. I ran IntelBurnTestV2.50 for 2 hours and the CPU peaked at 83*C and averaged 78-80*C. This heat will significantly degrade the life of my CPU and needs to be dealt with. As a result, I'd like to explore watercooling.
I currently have an EVGA GTX470. This thing gets HOT! It idles between 55-65*C and peaked at 93*C while running EVGA OC Scanner. However, it is currently being RMA'd. I'm going to try and upgrade it to the GTX470 Hydro Copper so I don't have to install an aftermarket GPU water block and void my warranty. I will be adding another GTX470 in the future.
I have a Corsair 800D case and I absolutely love it. It is a dream to work with and I'd really prefer not to modify it.
Would it be possible to use a single loop for OC'd i7 930, X58 chipset, and SLI'd GTX470s? I'm shooting for a 5*C temperature delta (Water Avg - Air In). I really think it would benefit from separate loops, but I'm not sure where I could place an additional radiator(s) without modifying the 800D. I'd also prefer not to use the Swiftech radbox. An external radiator would take away from the sleek look of the 800D.
I've read about every review / guide on skinneelabs and the stickies on XtremeSystems forums about 5x, but I'm still not sure what would be the best WC components.
http://www.skinneelabs.com/reviews.html
http://www.xtremesystems.org/forums/showthread.php?t=202394
Here is what I'm currently considering:
CPU water block: Swiftech Apogee XT extreme
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108113
I have heard that this water block is incompatible with some Gigabyte motherboards, specifically the EX58-UD3R. My motherboard (X58A-UD3R) is not mentioned on the incompatibility list, but I feel its layout might be quite close to the EX58-UD3R. Does anybody know if this water block will fit on my motherboard?
NB water block: Swiftech MCW30
http://www.frozencpu.com/products/2051/ex-blc-268/Swiftech_MCW30_SLI_Chipset_Water_Block.html
Is this a good choice for a northbridge water block? I'd like to use all Swiftech water blocks if I can (uniformity in the design). The chipset gets extremely hot due to the poor air circulation properties in the 800D. When I had the i7 OC'd to 3.6GHz, the CPU reached ~55-60*C and the chipset reached ~60-65*C. This is too hot. I'd prefer if it were below 50*C at all times (specifically ~40-45*C).
Pump: Swiftech MCP355
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108097
Is this a good choice? I heard the Apogee XT extreme is a comparatively restrictive CPU block and believe the MCP355 may be better for these situations compared to the MCP655. Is this a fair assumption? Should I use multiple pumps? I heard these have reliability problems compared to the MCP655. Could anybody offer further insight on this?
Pump Top / Reservoir: XSPC Acrylic Reservoir DDC Top
http://www.frozencpu.com/products/7226/ex-pmp-62/XSPC_Laing_DDC_Reservoir_Pump_Attachment_-_Laing_DDC-1T1TPlus_MCP-350355_No_Fittings.html
Is this the best top? Where should I install this in my case? I'm absolutely anal when it comes to maintaining a clean case (the reason I purchased the Corsair 800D was for the cable management). Is this significantly better than bay reservoirs? Is there anyway to install bay reservoirs without removing the drive covers?
Radiator: XSPC RX360 (with 3x push Gentle Typhoon AP-15s) or Black Ice GTX 360 (with 3x push or 6x push / pull Scythe Ultra Kaze 3000s)
http://www.frozencpu.com/products/8523/ex-rad-146/XSPC_RX360_Triple_120mm_Radiator.html?tl=g30c95s161
-or-
http://www.frozencpu.com/products/5326/ex-rad-109/Black_Ice_GTX_Xtreme_360_Radiator_-_Black.html?tl=g30c95s161
I live in a small apartment without central air. My room is ~100 square feet. I'm going to be purchasing a window mounted AC unit in the near future. I'm not sure how loud the AC unit is, but it will set the noise floor for my room. I also have two large fans operating in my room. I don't seem to mind them on high, but I'm also not sure how loud they are or how they compare to PC fans.
Are the Scythe Gentle Typhoon AP-15s the best fans for a low-medium flow radiator?
Are the Scythe Ultra Kaze 3000s the best fans for a high flow radiator?
I will of course be using a fan controller, but I'm not sure which one to get. Could anybody recommend a fan controller? How bad are the Scythe Ultra Kaze 3000s with a fan controller? Are they tolerable?
My Corsair 800D can fit a triple 120mm radiator at the top of the case. I can't decide between the XSPC RX360 and HWlabs GTX 360. I believe it will ultimately depend on the heat dissipation requirements of my system.
I used the CPU OC power calculator to determine power dissipation.
http://extreme.outervision.com/tools.jsp#cpuoc
At 4.4GHz (stock core voltage = 1.175V, OC'd core voltage = 1.3V), I'm getting 250 watts. However, I'm not sure how accurate that is.
The bit-tech review of the i7 930 shows it loves power (more than that calculator is suggesting)
i7 930 @ stock / idle = 124 watts
i7 930 @ OC (4.3GHz) / idle = 176 watts
i7 930 @ stock / load = 216 watts
i7 930 @ OC (4.3GHz) / load = 396 watts
http://www.bit-tech.net/hardware/cpus/2010/03/01/intel-core-i7-930-cpu-review/6
Are these numbers referring to system power or CPU power? What numbers should I go by?
I'm not sure how to determine the power dissipation of my GTX470. The [H]ardOCP review of the GTX470 shows the system pulling ~430 watts from the wall.
http://www.hardocp.com/article/2010/03/26/nvidia_fermi_gtx_470_480_sli_review/7
The PSU used in the review was the Thermaltake Toughpower 1200W PSU, which is 87% efficient. We might assume that system (GPU + other components) was receiving ~375 watts from the wall. I'm not sure how many of those 375 watts are being dissipated in the GTX470 compared to the other system components. Could anybody offer further insight on this?
Any thoughts on how to estimate the power dissipation of two GTX470s in SLI?
I have absolutely no idea how to estimate the power dissipation of the chipset.
I believe I must also take into consideration the heat dump associated with the pump I decide to use.
Of particular consideration is how we apply these estimates. We might simply sum the power dissipation of all the system components in the loop at 100% load and use that to determine the required radiator and fans. However, I'm not sure if this is representative of the real world. I believe all system components at 100% load is seldom observed.
I'm using this system for moderate gaming (Crysis), intensive multiphysics simulations (ANSYS, Cosmol, etc), Matlab, C programming, and miscellaneous engineering software. I'm currently using a Dell U2410 (1920x1200) as my primary monitor, so we might assume the system is going to be GPU limited (GPU @ 100%, CPU @ ?%) running games. Most simulation programs use the CPU for calculations, so we might assume the system is going to be CPU limited (CPU @ 100%, GPU @ ?%) in those application. However, once I familiarize myself with CUDA programming, I'll be using the GPUs for multiphysics simulations. I assume the system would be GPU limited in that application, but I am not sure of how significant the load on the CPU would be.
I will be adding two more monitors (considering the Dell U2311Hs) in the near future. I'm currently running two monitors. I'm not sure how that will effect the GPU load with traditionally CPU limited programs. I don't assume it will be a problem, but I'd like to cover everything.
With all of this in mind, how can we estimate system power dissipation in real world applications? I enjoy pushing my system as far as I can (within reason) using benchmark software (Prime95, IntelBurnTestV2.50, etc) to see what I can achieve, but its not THAT important.
A RX360 with 3x Yate Loon D12SH12 fans @ 1815RPM will dissipate ~280 watts before exceeding a 5*C temperature delta (this is what I'm designing for). It will dissipate ~580 watts before exceeding a 10*C temperature delta. I assume the performance of the Scythe GT AP-15s on this radiator is similar to the Yate Loon D12SH12s. Is this a fair assumption?
http://skinneelabs.com/xspc-rx360.html?page=4
A GTX 360 with 3x Scythe Ultra Kaze 3000 fans @ 2804RPM will dissipate ~580 watts before exceeding a 5*C temperature delta. It will dissipate ~800 watts before exceeding a 7*C temperature delta (empirical data does not exist beyond 800 watts) I'm not sure how much this will increase by adding 3 more fans and operating them push / pull. Any thoughts?
http://skinneelabs.com/hwlabs-gtx360.html?page=4
I don't think there is room for push / pull 38mm fans AND shrouds in the top of my 800D.
Do you think the RX360 would be sufficient for an OC'd i7 930, X58 chipset, and SLI GTX470s in a single loop?
I could probably install an additional 140mm radiator on the internal rear of the case (where Corsair recommends the H50 to be installed). Here is a photo (not my system, but it illustrates the idea).
However, I'm not sure if it will interfere with the airflow to the 360mm radiator at the top of the case. There is about 4.8 inches from the top of the 800D to where the H50 is currently installed and roughly the same (maybe a little bit more) to my DDR3 modules.
I dont't think I could install an additional 140mm radiator if I used the GTX360 with push / pull 38mm fans.
There are 3 140mm radiators available on frozenCPU that might work.
-Black Ice GTX 140
http://www.frozencpu.com/products/9017/ex-rad-156/Black_Ice_GT_Xtreme_140_Radiator_-_Black.html?tl=g30c95s929
-Black Ice SR1 140 (low air flow optimized)
http://www.frozencpu.com/products/10463/ex-rad-180/Black_Ice_SR1_Low_Air_Flow_Optimized_-_140_Radiator_-_Black.html?tl=g30c95s929
I haven't seen any scientific reviews (like the ones on liquidlab) of either of those radiators, but I assume their performance should be similar to their bigger brothers.
-Koolance 140mm High Flow Radiator (30FPI)
http://www.frozencpu.com/products/10199/ex-rad-176/Koolance_Single_140mm_Copper_High_Flow_Radiator_-_Black_HX-CU1401V_No_Nozzles_.html?tl=g30c95s929
This is probably very similar to its bigger brother as well (requires 1800+RPM fans)
If I went with a 360mm radiator and a 140mm radiator, should I put them in series or in separate loops? How would you distribute the system components amongst the radiators and how would you setup the loop order?
I read the review of the quick disconnects on liquidlabs. The Koolance VL3Ns look nice. However, I'd like to hear members experience using quick disconnects. Are they worth it? Have you ever had the liquid left in the disconnect spill and damage part of your system?
I'm sure I'm forgetting a lot of stuff. Please suggest something if you feel it should be considered.
Thanks,
Thadman
More about : watercooling system 930 gtx470
August 15, 2010 5:44:09 AM
first off...the block will fit your mobo because it fits a socket 1366 and your mobo supports that socket type also.
second...i would highly recommend towards NOT putting sli gpu in the same loop with your cpu specially if your cpu is going to 4ghz+. the heat from all that would prolly destroy your cpu. highly doubt you could keep the delta at 5c with all that heat.
with the NB getting to hot...just use the spot cooler from newegg. trying to WC your NB is really unneeded and most people just do it to just do it.
gtg but ill see if i can read the rest later
m
l
August 15, 2010 7:53:31 AM
I have the same motherboard with the Apogee XT it is compatible with the motherboard. But it has the the newer revision as it states here.
http://www.swiftnets.com/apogee%20xt%20revision.html
I bought mine from Koolertek like 2 weeks ago and it is the revised version.
here is a link
http://www.koolertek.com/computer-parts/pc/Swiftech-Apo...
Also I do not know if you know, this but the pump barbs are 3/8" the Apogee XT is 1/2" and the NB Water Block is 1/4"
So you might want to find the same size barbs. You can force 3/8" tubing onto the 1/2" barbs of the Apogee XT it just takes time.
Also if you want the best cooling, pump flow is more important then more fans on the radiator. I have a 240 rad and adding 2 more fans on a i7 920 @ 4ghz does not add any difference at all.
I recommend the MCP655 Pump
m
l
August 15, 2010 1:30:25 PM
That'll save me some cash and clean up the tube routing.
Is this what you're talking about (Scythe SY124010L 40mm Chipset Fan)?
m
l
August 16, 2010 5:34:56 AM
about quick disconnects...these guys have done an extensive amount of research on QDs and i trust their work.
http://skinneelabs.com/qdc.html
i wouldnt recommend them because im cheap and i dont like spending money but if you plan on taking your system apart alot i would buy it.
m
l
