Ok, so my roommate wanted to upgrade his computer and I told him I would do it. He kept his old keyboard, mouse, monitor, and hard drives.
I got him:
GIGABYTE GA-EP45-UD3R ATX Intel Motherboard
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
Intel Core 2 Duo E7300 2.66GHz LGA 775 Dual-Core Processor
Microsoft Windows Vista Home Premium SP1 32-bit for System Builders
Thermaltake Purepower W0100RU 500W Power Supply
+ my old X1950XT video card pci-e
Ok, so I reformatted his hard drive and installed vista on it. Everything seems to be working OK, except I'm getting a lot display problems and a few random resets (blue screens). I figure it is just the display driver. I get it hooked up to the internet and install a new chipset driver, a new video card driver and install all the updates for vista. At certain points I lose the display problem. However, it always comes back and a restart/shutdown does not get rid of it. The display error looks like a scrambled screen. It is almost like 3 mirror images of the same screen. I see a lot of tiny blocks, hard to explain.
After trying everything that I could think of, I put in his 2nd hard drive to try to install vista on that, and the display problem happens even in the bios screen and while installing vista.
Does anyone have any suggestions? I am installing vista on his 2nd hard drive to see if that fixes anything, but even during the install the display problem is present.
I'm thinking I might have a motherboard issue, but I am pretty clueless. I looked at the bios updates and none of them say anything about fixing anything like this. I know the video card is good, and I did a check on the memory and it checked out.
Any advice would be appreciated.
I got him:
