I need some advice on which components to purchase for air cooling. The last time I built a complete box was a while ago (before Prescott was released) and I did not OC, so cooling was not an issue at the time. I purchased the components for a new rig last night (minus the monitor and the cooling components).
This is the hardware that I chose:
Case: Lian Li PC-9F-B (Mid-Tower)
PSU: Corsair HX1000W (I could have gone with an 850, but I would like some room to OC and the calculator gave me an estimate of 891W without OC).
Mobo: ASUS P6X58D-E
CPU: Intel Core i7-930 (I would like to get this up to ~3.6-4.0 GHz)
RAM: 2x3GB Corsair Dominator TR3X6G1600C8D
GPU: 2x EVGA GeForce GTX 470 SuperClocked+ 012-P3-1475-AR (I chose this over the 1470 or 1472 for the High Flow Bracket + Backplate)
SSD: OCZ Vertex 2 OCZSSD2-2VTXE120G
HDD: Western Digital Caviar Black WD1002FAEX (I might add another of these into r0)
DVD: Samsung SH-S243N
So, that is the configuration. The two cooling components that I know I am going to purchase are a Yate Loon 140mm x 25mm Fan (optional slot on the top of the case) and Arctic Silver 5 Thermal Compound (unless someone has a better suggestion).
What I would appreciate help with is choosing the replacement for the stock CPU fan/heatsink and advice on other components that might be needed. I do not want to watercool (for now). Feel free to use technical language.
Thanks!
P.S. I cross-posted this on one other forum because I love both sites
Mobo: ASUS P6X58D-E
Thanks!
