Logon Problem - New XP Pro SP3
Last response: in Systems
Hi
I am new to the forum. I have just completed my first PC Homebuild. These are the component parts:
Gigabyte GA-EG43M- S2H Mobo - Intel Core 2 Quad Q6600 LGA 775 - 4 Gb Corsair DDR2 667 Mhz - Sata 2 500 Gb HD - Samsung internal DVD RW.
All parts are brand new never been used before or installed anywhere, all seem to work ok.
I bought a sealed new copy of XP Pro SP3 which had never been installed before. All went well till I reached the last stage of the installation when much to my surprise the system demanded an Administrator Password ?
Clearly, I have not created any passwords at all. Windows simply will not start. I receive the following error message every time
"The system cannot log you on due to the following error:
The specified domain either does not exist or could not be contacted.
Please try again or consult your system administrator.
I have even tried the Shift+F10 during the 'device install' part of the Windowd installation programme, to change /remove any paswords - this had no effect. I have tried 'Enter' with a blank password box, no effect whatsoever. It just refuses to start Windows XP.
Any help or advice will be appreciated.
Thanks
ps I have seen on the web that other appear to have had similar problems but no ready or obvious solution.
More about : logon problem pro sp3
Bigshot said:
Thanks. Where do I find the selector to choose between local system and domain?
At the bottom of the Logon window, do you see the OK, Cancel and Options >> buttons? If so, then click the Options >> button and select the local system in the drop down "Log on to" list if it isn't already selected.
Ask the community
