I recently upgraded psu to a antec signature 650w. I pulled out my old 400w psu and installed the new psu hooked up every thing and turned it on ... i got no post.
I have a agp HIS 3850 card installed in my abit IS7 mobo. I pulled out the video card and replace it with my old ati x800 card and turned it on... it posted and booted normally.
I then removed the x800 card and re-installed my 3850, turned it on and no post.
I disconnected the 20pin atx and the 4 pin p2 plugs and connected the two plugs from my old psu, i left the video cards power connector connected from the new psu, i ran the new psu to power up the video card, then i powered up the old psu to power up the mobo and it posted and booted normally.
I disconnected my old psu from the mobo and reconnected the 20 pin atx and 4 pin p2 plug from the new psu and turned it on and no boot.
works with new psu and x800 card
works with old psu and 3850 card
works when the new psu is powering the video card and old psu is running the mobo
Well, the only thing I can think of this that there's something wrong with the way you connected your new video card to your motherboard. If you think all the cables are hooked up properly, can you try the card on another slot on your motherboard?
It's possible your new PSU is faulty, in the sense that it's not providing enough power. That's why it fails when you try to boot the more power-hungry 3850.
