Solved
Arctic Cooling Freezer 7 Pro Rev.2 with a Phenom II X4 945?
a b K Overclocking
August 16, 2010 6:38:56 PM
Would this be a good choice for a Phenom II X4 instead of the stock cooler?
I don't intend to overclock at all, maybe 100-200 mhz tops but I'm not sure if it can keep one of these processors cool enough seeing as the cooler is a bit on the older side of things.
I want to avoid the huge 120mm coolers out there as they are simply too large.
Thanks!
August 16, 2010 10:04:30 PM
yes that will do fine and you should get 200-400mhz overclock
and make sure you use good thermal paste
m
l
Best solution
a b K Overclocking
August 16, 2010 10:59:27 PM
I would recommend the coolmaster Hyper TX3 thats a bit cheaper or the 212+ that cost a bit more (buts a 120mm one).
a c 183 K Overclocking
August 16, 2010 11:23:39 PM
^+1 I agree the CM Hyper TX3 is a better cooler then the AC Freezer.
m
l
a b K Overclocking
August 17, 2010 2:38:03 AM
That one looks great indeed, thanks for that!
m
l
a b K Overclocking
August 17, 2010 2:38:23 AM
Best answer selected by BounceDK.
m
l
