Sound card in my pc
Hello,
I can hear sound from pc,When I speak other person doesn't hear my voice, his settings are fine. Is there any solution how to know in and out is working or not? I tried with windows help..
3 answers Last reply
More about sound card
  1. Is the microphone switched on? Is the microphone volume on in volume control? Did you plug the microphone to the correct socket of the sound card? Also list the specification and the model of the equipment you use.
  2. Hi.. thanks for your answer.. I don't know what was wrong in the microphone, but I removed the sound card software and re-installing of the driver has solved my problem.
    Thanks..
  3. Glad to hear you fixed it ..Great Job! :D
Video Sound Cards Windows XP
