Hey guys. 2 part question. I currently have 2x2Gb of G Skill PI Black PC6400, which runs at 4-4-4-12. I have another 2X1Gb of G Skill ram I want to add, but it runs at 5-5-5-15. My guess is I should be able to manually set the timing to 4-4-4-12 in the bios so they all run at the same speed. Should this work? I'd really rather not buy another 4Gb of ram since nothing I run would ever use that much. The only reason I want the 6 Gb is because I run 3 instances of Everquest all from the same PC. EQ by itself will never use more than 2Gb, but as I understand it, each instance can use up to 2Gb. It runs fairly well as is, but I get some hesitation sometimes. The heistation, more like a video freeze, doesn't happen a lot, but annoying when it does. That leads to the second part.
My assumption is that its having to acess the hard drive more often pulling data for 3 instances at once. EQ is known for being a bit of a memory hog. I guess it could be the video cards, but I wouldn't think so. Opinions on vid or RAM here?
Specs in sig. Thanks for reading.
