Tom's Hardware > Forum > CPU & Components > CPUs > Persistent Heat Issue
Forum CPU & Components : CPUs - Persistent Heat Issue
Core i7 920, stock HSF, stock speeds.
My computer was idling at 45C and loading at 82C. So I opened it up, vacuumed out all the dust, and replaced the thermal paste with perfectly-applied Arctic Silver 5. Then I chilled my room and started her up again, seeing idles of 25-35C. Perfect, right? Hum. Every day it went up a little more, and now I'm idling at 46-50C in the same ambient temperature! Load temperatures grazed 70C but never really went higher, stabilizing around 65. Should I be concerned? The paste bottle said it would go down over time as the paste set in, but it's been rising very gradually. I'm pretty freaked out. (48C totally and completely blank of programs as I write this. Sitting in the BIOS I get the exact. Same. Temperature.)
Sponsored Links
My Core2Duo idles at 40'C and gets to 50-56'C at load, and Core2Quads are hotter than Duos, and i7Quads are hotter than Core2s.
I think your temperature is fine.
Message edited by Bluescreendeath on 05-07-2009 at 05:49:04 AM
------------------------------ i7 920, E5300
GTX260, HD4870, HD4830
Reply to Bluescreendeath
- 0 +
Sounds like the HSF is not well seated on the cpu ... a retention clip is not locked.
Try removing it and reseating it again - simply check the grease is evenly applied when you take it off but no need to put more on I'd say.
Here is a great little guide ...
http://www.pcstats.com/articleview [...] 385&page=2
The i7's pump out some heat when loaded up ... very fast though.
http://www.bit-tech.net/hardware/c [...] oup-test/1
If you have little joy I'd consider an aftermarket cooler.
Good luck !!
------------------------------ Great spirits have always encountered violent opposition from mediocre minds
Reply to reynod
^ I'm surprised they got the cpu temperature into the teens.
I've read other articles that state that i7 temps are widely varying, and run very hot...sometimes reaching 90'C and over.
Good luck !!
Hey - thanks, but I've reseated the cooler several times, and reapplied the paste in the "strip" shape exactly as shown in the guides. Initially I lined it up wrong so it went in between the cores, but when it shot to 80C in the BIOS I redid it and it dropped to 25 over time.
People tell me it's fine, and I know it's not damaging - it's the radical shift that concerns me.
Reply to doctorhorrible
- 0 +
I'd get an aftermarket cooler ... just to be on the safe side.
I don't buy into the crap on grease - just clean both cpu and cooler base ... put a new blob on the size of a grain of rice and smear it round with your finger to even consistency then remount it.
Simple ... been doing it since 1982 that way ...
Reply to reynod
There are 1104 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
