New system build, need some advice...
elrondemon
25
Hello, I'm currently building a new system.
This is what I'm on right now:
CPU - E8400 / Q6600 (still deciding)
Motherboard - thought of one of them: EP45-DS3R, EP45C-DS3R, EP45-UD3R, EP45C-UD3R
Does the UD3P worth the extra $? or one of those will do the job perfectly? which one is recommended?
VGA - probably going for the HD4850, I read that it definitely worth the extra cash over the 9800gt
Memory 2*2GB of the OCZ 800mhz
Hard disk something around the Seagate 500GB
Case the beautiful Antec 900
Cooler not sure yet, probably the big typhoon, any good suggestions? i'd be glad to have something cheaper that will do the job.
PSU one of the following brands: corsair, enermax, thermaltake the cheapest possible that I can trust...
thx a lot in advance....
The UD3P is worth it. Best P45 board I know, and it's future-proof since it supports Crossfire and you're getting a Crossfire card.
Forget the "C" models. Dual DDR2/DDR3 support is pointless, since you can't use both types at the same time. Why dump the DDR2 and replace it with DDR3 when that makes no difference in speed.
Get WD disks, preferably the 640GB version. Seagate is flaky at this point.
Get a Corsair 650W. That will allow Crossfire with HD 4850 cards, and it's very high quality.
Between E8400 and Q6600 - get the Q6600 if you play FSX or GTA 4 or encode videos often.
elrondemon
25
thank you for the reply.
I'm not planning to use crossfire.
can you be more specific please, why the UD3P is better than the DS3R and the UD3R?
will the corsair 450w hold my system? or should i go bigger like the thermaltake 550w or the corsair 520w??
how about the cooler?
If you're not planning to use Crossfire then the UD3R is actually a better choice IMO than the UD3P because it has 3 PCI slots instead of 2. Both are excellent overclockers. The UD3P's second PCI-E x16 slot could however be useful if you ever want to use 3 or 4 monitors. (That is, with the UD3P you can add a $30 card and connect it to monitors 3 and 4)
The DS3R is OK too. However, I'd stick with the newer models UD3P or UD3R. They have better cooling and more SATA ports.
You can compare them all here:
http://www.gigabyte.com.tw/Products...ComparisonSheet.aspx?ProductID=2842,2919,2921
Yes the Corsair 450W can do the job. Sapphire recommends 450W or more for a system with a HD 4850, and the Corsair 450W is very powerful for a 450W PSU. That is, it offers more A on the 12V circuit than most other PSUs that claim 450W.
Cooler: are you looking at this one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106061
It's not bad, but there are better ones for the price, like this Xigmatek for example:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233024&Tpk=xigmatek knight
If you get a retail version of the CPU and don't overclock then you don't even need to buy an aftermarket cooler, of course.
elrondemon
25
I wanted to know if the corsair 450w psu will hold my 4850 vga?
will my ud3r mobo and the q6600 be good for overclocking in the future?
the nine hundred case doesn't have any fan filters? is that important? can I buy them and put them in?
any good suggestion for cases for the same price?
elrondemon
25
thank you very much...
few last questions:
any difference between the gigabye 4850 and the sapphire 4850? which one will fit my system better, or it doesn't matter?
can't decide which case to take: 900 / V9 / VH8000?
can you be more specific please about cleaning / building my own filters in case I buy the 900?
thanks!
xthekidx
Splendid
Dec 24, 2008
3,871
Saphire is more reputable as a GPU brand, but it probably doesn't make too much of a difference. Check the warranty info and prices and go with the better deal, both will be compatible with your system and will be the same size.
About cleaning: buy a can of compressed air (e.g. http://www.newegg.com/Product/Product.aspx?Item=N82E16882889003) Use it often if you have cats :)
Making your own filters: TBH I have no idea how. I just remember reading about it in some Newegg reviews.
I like that V9. You are talking about this one, right?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133074
4870 512mb > gts 250 1 gig > 4850 1gig
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127421 $149.99 ($134.99 after $15.00 Mail-In Rebate)
MSI N250GTS-2D1G-OC GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready Video Card - Retail
http://techreport.com/articles.x/16504 <--- gts 250 review.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022 $79.99 ($59.99 after $20.00 Mail-In Rebate) Free Shipping*
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359 $114.99 ($99.99 after $15.00 Mail-In Rebate)
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209 $44.99 Free Shipping*
G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319 $79.99 Free Shipping*
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152 $23.99 Free Shipping*
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner - OEM
elrondemon
25
hmmm your reply doesn't really connected to my questions...
Can anyone suggest me anything about the case?
V9 / 900 / VH8000 / Tempest
