Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Gigabyte EP45-UD3P sound issues
Forum Motherboards & Memory : Gigabyte - Gigabyte EP45-UD3P sound issues
I just bought this new motherboard gigabyte EP45-UD3P and install new windows xp3 with new realtek sound driver from web site(also tried the MB CD). Im having problem with 5.1 sound output.. My speaker setiing is selected as 5.1 from windows control panel.. Realtek HD audio manager (5.10.0.5780) set to 6 speakers. All the speaker tested from realtek audio manager seems plays sound perfectly but When i play music with winamp and media player 11 only 2 front speaker sound is coming out but center and rear(set as side) speaker has no sound.... can anyone help me pls...
Sponsored Links
If you're playing back MP3s, there's only two channels there to begin with... Stream some HD video, and you'll hear it right away...
Reply to bilbat
thanks for quick reply... yah its true when i play dvd i hear all speakers... but my last gigabyte MOBO played all the mp3 5.1 too with winamp... so is there any option to set it up to play mp3s 5.1......?
Reply to deadbody
- 0 +
Simply go into the audio manager, and enable this:
http://img411.imageshack.us/img411/6447/0010f.jpg
From WikiPedia:
"DTS Neo: like Dolby's Pro Logic IIx system, can take stereo content and convert the sound into 5.1 or 6.1 channel format..."
Reply to bilbat
that didnt help "bilbat"... still 2.1 sound coming but thanks
the stange thing is in "realtek HD audio manager" if i turn oragne c/sub, and black Ls/Rs, green L/R to
orange L/R, black L/R, green L/R so basically all L/R (Front speaker output) than all chaneel speakers sound is playing fine....
any ideas????
Message edited by deadbody on 07-10-2009 at 04:46:39 PM
Reply to deadbody
- 0 +
Ackk! I think you may be stuck, then. My audio hardware (Logi X-540) has a 'matrix' function to accomplish this, so I couldn't tell if the NEO does anything... If that doesn't work, I don't know what to tell you - if the audio streams aren't there, well, they aren't there! The NEO function isn't that hot to begin with - if I leave it enabled, I get audio 'stuttering' in HiDef 5.1 streams... I'll keep looking, and post back if I find any kind of solution!
Reply to bilbat
- 0 +
I have a EP45T-UD3P board (btw, does anyone know what the "T" delineates) and I also have had to deal with this same annoyance but, alas, with Winamp I have found an albeit rudimentary solution that works.
Go to the DSP plugins section on the Winamp website and download Blade DolbyMP Encoder. It actually works pretty well. How, I'm not sure. I think it splits the center channel into surround, but I find that it does a great job and adds a whole new dimension to my MP3s. Check it out.
Reply to weikelp
- 0 +
Quote :
The 'T' suffix board are the DDR3 variants...
Reply to bilbat
nope "Blade DolbyMP Encoder" not working for me either.... I have dps plugins still 2 channel sounds im getting.... I think we need a solution from realtek.... Im gona try another windows too and let u guys know too... thanks
Reply to deadbody
- 0 +
Try a peek here:
http://www.corel.com/servlet/Satel [...] 6741481082
they probably have a trial download...
If you don't mind the time converting files, I think this:
http://www.nidesoft.com/mp3-converter.html
will convert 2.0 MP3s into 5.1 AACs; if it works for you, it might be worth a trip to Seek'nDestroy - wink ;)
Another few possibilities that turned up are here:
http://www.hydrogenaudio.org/forum [...] 27803.html
and here:
http://www.iis.fraunhofer.de/EN/bf [...] /index.jsp
Reply to bilbat
bilbat wrote :
Quote :
NO...the t is for the "Trusted Platform Module" or TPM, like bitlocker for hardware, if someone steals your ram or hd and such (and other devious future uses), your mb has a fit because the TPM stores the hardware key, as well as pseudo random seed function.
see item 6.
Built-in TPM chip with 2048bits encryption to highest level digital data protection
http://www.gigabyte.us/Products/Mo [...] uctID=3015
------------------------------ E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
- 0 +
Quote :
NO...it's not...
colored one way:
GA-EX38T-DQ6 DDR3 no TPM header/support
GA-EX38 -DQ6 DDR2 no TPM header/support
GA-EP45T-UD3LR DDR3 no TPM header/support
GA-EP45 -UD3LR DDR2 no TPM header/support
GA-EP45T-DS3R DDR3 with TPM header/support
GA-EP45_-DS3R DDR2 with TPM header/support
GA-EP45T-UD3P DDR3 with TPM header/support
GA-EP45_-UD3P DDR2 with TPM header/support
GA-EP45T-EXTREME DDR3 [u]no[/u TPM header/support
GA-EP45 -EXTREME DDR2 no TPM header/support
colored another:
GA-EP45 -DS3R DDR2 with TPM header/support
GA-EP45 -UD3P DDR2 with TPM header/support
GA-EP45T-EXTREME DDR3 no TPM header/support
quod erat demonstrandum...
Reply to bilbat
Looks like your right !
"which was to be demonstrated"
Reply to royalcrown
ok guys i did install new windows... but still no solution.. One thing I wanna know my last motherboard was also gigabyte (ga-965p-ds3) and it did play same mp3 songs through winamp and wmp11 at 5.1 with no problem... than why this latest mobo cant play mp3 at 5.1 channel... Even the Realtek HD audio manager config looked same in both MOtherboard.. all i change in my last mobo in "Realtek HD audio manager" 2 channel to 5.1 and it played 5.1 sound....
I even mailed gigabyte and here what they replied
Thank you for your kindly mail and enquiry. Whether the multi-channel enabled or not is also depend on the media file you played and also the player you're using, we suggest you can contact Microsoft and Winamp for instruction to enable multi-channel while playing audio file.
I am so pissed with GB now...
how do guys post pics in this forum anyway...?
Reply to deadbody
- 0 +
I always use ImageShack:
http://load.imageshack.us/
I believe you have to register there first; it will allow you to browse to an image, and then upload it; once it is uploaded, it will give you a couple of "Links for Forums" to your picture; they look like this:
URL=http://img512.imageshack.us/i/latestcomps001.jpg/][IMG=http://img512.imageshack.us/img512/2530/latestcomps001.jpg][/IMG][/URL
(I took the brackets off the outer ends to show it properly) I copy this and paste it to a temporary notepad, then copy this part: "http://img512.imageshack.us/img512/2530/latestcomps001.jpg" to this box:
http://img268.imageshack.us/img268/9563/0012j.jpg
which pops up when you click the add image button on top of the posting window (you must have "Allow websites to prompt for information using scripted windows" enabled, under security settings in IE)
Click 'OK' and, voila, it appears:
Reply to bilbat
thanks bilbat... now I know how to add pics..
Reply to deadbody
There are 510 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
