Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Upgrade to nVidia GeForce 9800 GTX+ - Power Supply
Forum Graphic & Displays : Graphics Cards - Upgrade to nVidia GeForce 9800 GTX+ - Power Supply
I've been running my computer, a Dell Dimension 9150, for about 3 years now and have decided to replace my old 6600 GT graphics card. I've been looking at the 9800 GTX+, but according to nVidia this requires a 450W power supply, while Dell cites my computer as only having 375W. I have read however, that Dell underrates its power supplies. Will I need to upgrade my power supply to use this card, and if so, would something like a 8800 GTS run with 375W?
Thanks in advance,
Tom
Sponsored Links
Your PSU have 83.3% Efficieny. Thats why it is said to have output of 375W.
For 9800GTX+ i'll recommend you to get a 80Plus certified PSU of about 550W.
Reply to meodowla
His psu has an efficiency of about 72%, I determined this by using a killawatt meter to see the amount of power drawn from the wall, then replacing the Dell psu with a known 82% efficient psu ( Antec EA430 ) and witnessing a 10% decrease in in that power draw.
It's said to have an output of 375 watts because that is it's max continous output rating.
Aerius, a 9800 GTX+ that uses a single power connector shouldn't have a problem running on your machine. It uses less power than an older 8800 GTS 640 OC, that I still have running on a Dell 375 after 2+ years.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
There are 1309 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 torbee won the Freshman badge
  • 01:00 dba won the Uniformed badge
  • 01:00 LoveMyslf won the Uniformed badge
  • 01:00 survdirt won the Uniformed badge
  • 01:00 vgigolo won the Uniformed badge
  • 01:00 alex3003 won the Uniformed badge
  • 01:00 dindarloo won the Uniformed badge
  • 01:00 Akash Nain won the Uniformed badge
  • 01:00 greeneman510 won the Uniformed badge
  • 16:28 bilbat won the Motherboards badge
