alright, so I just got my system built and finally got it to boot this weekend. Got vista installed, tried to run hal-life 2 and got an error message:
failed to lock vertex buffer in CMeshDX8::LockVertexBuffer
already contacted steam support though, so that's taken care of for now.
So I decided since hl2 would not run, lets go try cod4 and crysis to let my 4870 x2 flex a bit.
So i downloaded the crysis demo and cod4. I ran crysis first, and after starting a new game, about 8 seconds into the opening video, I got blue screened.
So i decided, fine cod4 then.
On it I got to just before it loads you up for the training course before I got another bsod.
So, I google it, see that it could be driver related. uninstalled the drivers, reinstalled em (CCC/DD 9.1).
I also read it could be caused by over heating, so I went into the advanced CCC and lowered the gpu/mem clock on the card by 50 mhz and pumped the fan up to 65%.
tried running crysis again, same thing happened.
by now I am getting more po'ed, I decide that I will just test it in 3dmark.
tried to run it and it caused my computer to restart without any bsod or error messages.
Now, I think I may know what the issue is, but just want to check with others first.
My new psu decided to commit suicide the second time I tried to use it, dont think that it got to anything else though. It's being rma'ed and I am getting a replacement on tuesday (its an 800w ultra X3).
For right now I am using a 680w Apevia.
I am thinking that my system uses maybe 400 to 500 on idle, then when I go to play a graphics intense game, it maxs it out and its bsod time.
I think this because I am able to play COD 1 without any issues.
So, if someone could take a look at my setup and see if that is the case, I would appritiate it:
OS: Windows Vista ultimate 32-bit
MB: Asus maximus II
Ram: 4 x 1 gb sticks ddrs pc8500
Gfx CArd: Sapphire Radeon HD 4870 x2
Sfx Card: Crative X-Fi extreme gamer fatal1ty edition
Proc: Intel 2.4 Ghz Q6600
1 sata HD
1 120mm fan connected at the moment
Thermaltake Big Water 760is
and a sony dvdr/cd rw combo drive
Idle Stats (in case its an overheating issue):
cpu: 20 to 25C
gpu: 42 to 46C
Full Load Stats:
cpu: 28 to 35C
gpu: 51 to 60C
MB: Asus maximus II
1 sata HD
cpu: 20 to 25C
gpu: 42 to 46C
Full Load Stats:
cpu: 28 to 35C
gpu: 51 to 60C
