Solved
What are the best AM3 coolers for the 1055t without water cooling
I would like to get information, suggestions on the best known cpu coolers that perform with temps with around 55c and below would be nice the lower the better, any help will be awsome.
8 answers Last reply Best Answer
More about what coolers 1055t water cooling
  1. Corsair H70 is a nice choice. It's a factory sealed water unit which means there's no more installation than a simple air cooler, yet it's actually a liquid cooling system. Temps on the 1055T are around 60C under full load at stock speeds (going from a youtube benchmark) but might be more depending where you live and what cooling you have in your case.
    The Prolimatech Armageddon or Megahalems are both AMAZING coolers.. but you'll need to source the AM3 bracket for them which most shops do not supply. I believe performance pc's might sell it though.
  2. Akasa venom. shouldnt be a choice
  3. Best answer
    I did some recent testing myself see http://www.tomshardware.co.uk/forum/261270-11-coolers-tested-hear-results hope its useful
  4. I use the Xigmatech Achilles S1284W on my 140w phenom ii x4 465 and at idle it's around the 35 mark after gaming it reaches around 55. I don't believe your 1055T would produce more temp then the 140w 465 I use.
  5. Oh yeah, it's a good price to, I got mine for £28 off Amazon.
  6. Best answer selected by mstc7stream.
    Hay there Simon12 awsome just what i needed spot on (:
    Thanks for the reply acer0169
    yes i have to say i like the Corsair H70 im gonna try fan forced first and then give this H70 ago to see the difference nice work i have to say keep it up.
Heatsinks Water Cooling Cooling CPUs Overclocking Product
