Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem with 1980x1200
Problem with 1980x1200 @60Hz
Forum Graphic & Displays : Graphics Cards - Problem with 1980x1200 @60Hz
When i make a connection between Samsung T260HD (it does support 1980x1200@60Hz) and my GeForce FX5600 using a DVI-D cable if I set the resolution at 1980x1200 the screen doesn't show all the desktop image leaving an hidden area on the right(or left)...if i move the cursor i can see it as a scroll....with other resolution it works...with a vga cable it works also at 1980x1200...
a graphic card problem? How can i solve it?
thanks
a small video about my problem...
http://rapidshare.com/files/205683804/13382.avi.html
Sponsored Links
I don't believe that card supports that resolution. I did a search and this is what i came up with.
# Supported Display Graphics 848x480 , 1152x864 , 1280x960 , 1360x768 , 1920x1200 , 1920x1440 , 2048x1536 , VGA (640x480) , SVGA (800x600) , XGA (1024x768) , HDTV (1920x1080) , SXGA (1280x1024) , UXGA (1600x1200) , SXGAW (1600x1024)
Reply to PsychoSaysDie
but there is 1980x1200....maybe it works only with vga?
Reply to clamilan
sorry when i've written 1980 before i mean 1920....
Reply to clamilan
Does it work with 1920X1080?
there in not 1920x1080 in the menu of resolutions...
Reply to clamilan
I totally missed where it said 1920X1200. I dunno bro.
There are 1359 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
