4850 x2 fps "problems"
So i have my own 4850x2 :)
in tiger direct thay say that this card does in crysis 51 :o FPS!!!!
i tried it and i had 29fps..... WHY???? plz help thx! :(
11 answers Last reply
More about 4850 problems
  1. Dont listen to stores reviews,check out reviews from tech sites.
    what are your system specs? what resolution do u play at and what settings do u use ?
  2. ^^^agreed, system specs, resolution and settings are the major things that will determine your FPS
  3. Probably the 51fps are in medium settings not veryhigh settings.
  4. ^ The chart says Crysis v1.2.1 "Very High Details"
    @gatroo, What resolution are you playing on?
  5. michaelmk86 said:
    http://media.bestofmicro.com/Z/B/177527/original/gtx-285_charts-03.png
    That isn't the right card either. Maybe you were just trying to guesstimate?
  6. Guys Guys.. i fixed it :)
    i just enabled the crossfirex and now i how 43 fps in crysis gamer 1680x1480 :)))))))))))))))))))
    Yeah, I was just going to suggest that :) There is an option under catalyst control centre to show icon when crossfire enabled, so you can enable that just to ensure that you have Crossfire enabled in each game.
    HD4850 x2 is an awesome card, have fun with it!
    BTW, do you have the 2GB version or the 1GB version?
  8. i have the 2gb :) but i still got lower fps than other people from youtube and from the internet still dunno why xD
    like...one man shows that he got it 3dmark06 20152point well i got 16682 and my system spec is: Core 2 Quad 3ghz :D
    ATI 4850x2 2gb
    4GB ram/windows vista 32bit 850w AKASA + 9.2 catalyst maybe all becouse the catalyst?????? :S
  9. Cat 9.2 is trash. Youll probably see better results with 8.12
    ATI 4850x2 2gb
    Yeah I got 17620 with 3D Mark 2k6 and I have a Phenom II X4 940 @ 3.515 GHZ so that sounds about right. Also I am using Cat 9.2.
    Cat 9.1 Will give you best performance but they have some unresolved bugs
    We should be getting the Cat 9.3 in coule of weeks, and they will have performance back up with bugs fixed, so just hold on for another couple of weeks.
    You can still play at max setting and high res, unless you are really a 3D Mark 2k6 Junky ;) and you really want to switch back to Cat 9.1
  11. Lets hope that ,that 9.3 is coming out soon :sol: becouse i dont know how to downgrade to 9.1 LooOoOl
    ATi POWAAA XD :pt1cable:
Graphics Cards Tiger Crysis FPS Graphics
