I just built a new machine and it's having some really ridiculous issues. The computer's components are also listed on my profile, but I will cut and paste here:
2.4GHz Intel Core2 Quad (which I hope to overclock once it's up and running)
4GB of DDR3 RAM
Intel mobo
650W Rosewill PSU w/ variable speed fan
300GB, 10,000 RPM SATA2 hard drive
80GB, 7200RPM SATA2 hard drive
80GB, 7200RPM SATA1 hard drive
Also, an Arctic Cooler heatsink on my CPU and some nice case fans.
So, my buddy and I put together this machine and installed two different boots of WindowsXP on two different partitions of my 300GB sata drive (one partition was 30GB the other was 35). Both boots were working just fine. One was connected to the internet (C, the other was not (D. The non-internet boot was strictly for working on music, and I wanted it to be streamlined so that no extra, un-needed processes were running. For the record, though. Both boots of XP were working just fine.
To achieve this, I applied several tweaks off of a list of tweaks from www.musicxp.net. After applying the tweaks (to that particular boot of windows ONLY), I rebooted so I could go online on the other boot of windows and download a couple disk maintenance and diagnostic tools. When I got to the boot selection screen, I picked the net-connected boot and was told that the SYSTEM file was missing from windows\system32\config\system. I rebooted and tried the D: drive and got the same message.
I ran the Windows setup CD in repair mode and searched around on the C: drive and it was true. The system file was not there. I don't know why.
After trying things fruitlessly for a while, I gave up and decided to reinstall windows. Upon trying to do so, the windows installer told me that it couldn't format the drive because it was either corrupt or a cable had come disconnected. The latter couldn't be true, because it was still reading information off the drive (i.e. the location of files and folders on the drive, partition information, etc), and a SATA cable is either plugged in or it isn't. This drive is brand new as well.
I ran the "Ultimate Windows Boot Disc" and ran a bunch of diagnostic tools and couldn't find anything wrong with the drive or the RAM (though I admit I only checked the first 1GB). After running that and rebooting, it didn't even get to the boot selection screen. It just said "error loading operating system."
Please help me. I have exhausted all of my knowledge in figuring this out.
Help me, Obi Tom('s Hardware) Kenobi, you're my only hope.
4GB of DDR3 RAM
Intel mobo
