Q6600 Overclocking problems
Hey everyone im new to these forums, i thought id sign up to try get some help.
i have a q6600 G0 on my gigabyte 965p -ds3 mobo, which i have been running 3ghz 333x9 multiplier and 1.375V with 3gb ddr2 800 ram with safe temps etc. i have turned off visualization, CIE, EIST that stuff.
The other day however i decided to try 3.4ghz on 1.4v, my bios made the post beep, but then it just hanged on the logo screen a little longer then normal ( like 3 - 6 secs) then my screen goes black and it restarts. when i go into my bios my fsb is set back to the defualt for 2.4ghz and whenever i now try to change it (up or down) the same thing happens where it posts like normal but restarts after the logo screen.
I have also tryed raising FSB voltages, ram voltages cpu voltages nothing seems to want to work.
i would really appreciate it if someone could help me.
thanks.
2 answers Last reply
More about q6600 overclocking problems
  1. Have you tried clearing the CMOS?
  2. Do you mean taking out the battery and letting it discharge?
    yeah Ive done that. thanks.
CPUs Overclocking
