Hi everyone,
I will upgrade my system and want to know what do you think about the parts I will have.
New part
MOBO: Asus P6T V2
MEMORY : Dominator TR3X6G1866C9DF 6GB DDR3-1866 CL 9-9-9-24
CPU : I7 920
PSU: HX1000W
part to be reused
COOLING : Freezone elite , I already get the bracket for the lga 1366
CASE : TJ09
HD : 2 raptor, 2 640gb
DVD : Blu ray , dvd burner
VIdeo card : BFG GTX 295
Plan OC : 3,9~~4.2 ghz
Future parts to get
Video card : BFG GTX295 sli.. quad gpu .. something like that
Ram : another 6 Gig for a total of 12 gig.. Lot of video processing.
3 small questions:
1- Did my freezone Elite will do the job for the I7, when i look in some forums it looks like some have good result an other not so good .What do you think it is better to go air or to keep my Frezone.
2- It's look like for overclocking the I7 memory it's a key to get good result. Did that memory his overkill , if yes can you tell me the part I should get instead.
3-With all the parts I have is it a good choice to go with the Hx1000w
New part
MOBO: Asus P6T V2
CPU : I7 920
PSU: HX1000W
part to be reused
CASE : TJ09
Future parts to get
3 small questions:
