Need help, Are These parts Compatible
ponpulla
Ok i guess you looking for a cheapo AMD HTPC possibly to do blue ray on the integrated video right? Some notes:
1. DDR2 1066 will downclock to 800 unless paired with an AM2+ chip so with a 5600+ brisbane just go with a 800
2. Why not get an mATX 780G/GF8200/8300 and a nice shoebox/mATX casing so it's portable to move from LCD monitor to TV (if applicable hehe)
3. Ok some peeps may go ballistic at your choice of PSU+casing but some of them run a 1KW nuclear plant in their rigs i.e way over estimate power requirements but since i do up IGP rigs a lot: understand that the PSU that came with the case is fine if strictly on integrated video else even with a GF8600 or older GF7800/Radeon 1800 you'd be looking for a PSU upgrade ^^
Hoped i helped!
theAnimal
2,370
Quality of PSU is as important as size. That PSU is crap. If you like the case, buy it with no PSU and add a 300W Seasonic. If you want a case that comes with a good quality PSU, look at the Antec NSK series.
ponpulla
Okay So I USed
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBNT - Retail *link* http://www.newegg.com/Product/Product.aspx?Item=N82E16820231207
Ill be Better Off using this Ram With My MoboAndCPu?????
