Hello,
I am new to this forum and thought I would give it a go since I have heard great things about it. Anyway I am not new to computers and have been building for a while now.
I recently built a system for a friend of mine with the following specs:
MOBO - Gigabyte EP35-DS3
CPU - e8400 @ Stock (3 Ghz)
RAM - 2 x 1 Gig Corsair XMS2 800
GPU - Gigabyte 9800 GT FOC
PSU - Corsair HX520 520 W
HDD - Seagate 160 GB HDD (Sata)
CASE - Gigabye Sett0
Anyway the problem I am having is that the computer will randomly not boot up properly, where it will just continually reboot every three to five seconds. This is a problem as I have now handed it over to my friend and the problem is occuring again after dissappearing. In addition, while I was configuring it the orientation seemed to affect this problem. Whenever the case was sitting upright this problem would persist, however when I turned the case on its side the problem dissappeared. This is getting really frustrating and I am not sure what that problem is because it was working fine for a while, as in I had time to install XP and a range of software applications, including some games, which also worked fine when tested.
Secondly, I am slightly worried about the idle and load temps of the CPU. I know the e8400 have problems with getting accurate temperature readings, however when I used prime95 to do some stress testing, one of the cores went up to 75 C in speedfan, at that point I stopped the test to prevent hardware damage.
Additional Information:
- GPU had to be send away because off foreign substance causing a short on the PCB
- CPU's heatsink has been pulled off and reseated, however no new thermal paste was applied (maybe that is the temp problem)
- Temperature monitoring and stress testing was done in A/C environment with approximately 24 C
Any help would be greatly appreciated. I suggest we tackle this problem one step at a time and I would prefer to have the rebooting problem fixed first as it is really becoming a frustration.
Kind Regards
ZeGerman
Kind Regards
ZeGerman
