Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Bad Corsair CMPSU-550VX power supply?
Received my Corsair CMPSU-550VX Friday; waiting for MB delivery on Monday. In the meantime, I plugged in an Antec PSU tester (the older model: http://www.amazon.com/gp/product/images/B00006B6U0/ ). The Green LED on the tester comes on, but using a VMM, when I test the +5V pin on the Antec tester, it first goes to 5.1V upon power on, but in about 5 seconds, drops to 3.67 V. Is this a bad sign for my brand new Corsair PSU? Or is there some sort of incompatibility between it and the Antec tester?
Sponsored Links
Cut and pasted from something I wrote a while back:
Try to verify (well as you can) that the PSU works. If you have a multimeter, you can do a rough checkout of a PSU using the "paper clip trick". You plug the bare PSU into the wall. Insert a paper clip into the green wire pin and one of the black wire pins beside it. That's how the case power switch works. It applies a ground to the green wire. Turn on the PSU and the fan should spin up.
If it doesn't, the PSU is dead. If you have a multimeter, you can check all the outputs. Yellow wires should be 12 volts, red 5 volts, orange 3.3 volts, blue wire -12 volts, purple wire is the 5 volt standby. The gray wire is really important. It sends a control signal called something like "PowerOK" from the PSU to the motherboard. It should go from 0 volts to about 5 volts within a half second of pressing the case power switch. If you do not have this signal, your computer will not boot. The tolerances should be +/- 5%. If not, the PSU is bad.
Reply to jsc
Thanks jsc -- Trying the paper clip test you suggested, I tested all of those rails and they are OK, in particular the +5V, which is good news!
Out of curiousity, why would the Antec tester would give me different results, i.e. 3.65V on the +5V rail on the Corsair? If I use the tester on a different PSU (Earthwatts 380), the +5V is measured as 5V.
Reply to unprovoked
Just to followup. I received the MB, and the Corsair was in fact bad. Would not boot MB for more than 1 second. Swap in of different PSU worked, so problem was isolated to new PSU.
Reply to unprovoked
Sorry you got a bad PSU.
Corsair RMA Link: http://www.corsair.com/helpdesk/default.aspx
------------------------------ Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
There are 1308 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
