Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Help using VGA/Super VGA Monitor
Forum Graphic & Displays : TV/Video Cards - Help using VGA/Super VGA Monitor
I just purchased a VGA replacement cable to connect my Gateway laptop to my 37" HDTV (Toshiba)...I connected it properly and it works until I try to play my Windows Media Player or some other DVD program. Any suggestions? Did I buy the wrong cable?
Sponsored Links
What monitor setting are you using? There are three for laptops, display on both screens, display on laptop only and display on external screen only. For video I've found you need to display on the external monitor only (I'm assuming your using dual display). Try that out...
Reply to kamel5547
There are 1062 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
