I recently bought parts to build a new computer...it is my first time...i am a computer building virgin
Anyways me and my friend hooked it up...my power supply was DOA..so i got a new one....then after i got that in...it turned on..but now nothing displays in my monitor.. so i thought it was my graphics card.. but we put my graphics card in my friends comp and it worked...so now it might be the motherboard?
My luck is really crummy
POWER SUPPLY:
PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply compatible with core i7 - Retail
http://www.newegg.com/Product/Prod [...] 6817703009
try resetting the cmos by shorting the 2 pins next to the motherboard battery for a couple seconds...see page 7 for location and page 33 of the manual for the instructions...good luck
------------------------------antec p180
gigabyte GA-MA785G-UD3H
Phenom II X3 720 BE @ 3.5
g-skill ddr 1066
Reply to pont
