I just installed a 512mb Gigabyte 9800gt into a system that was previously just using an on-board GPU. Its a brand new video card, was working perfectly fine for about 3 hours with the card installed nicely, then my pc just shut off unexpectedly.
If i slot in the 9800gt and plug in the 6-pin power cable from the PSU, then turn on the pc, absolutely nothing will happen, no power anywhere (sometimes the CPU fan will spin for a split second and power off again). If i unplug the 6-pin power cable but keep the video card in the pci-e slot it will boot up, but it takes a while for the monitor to display the boot process if i plug my monitor into the on-board GPU.
The pc works perfectly fine if i take the video card out completely and just use on-board.
Well actually the PSU is the culprit here....it was not able to handle ht 9800GT for long...it was only able to handle it for abt 3HRs and gave up i think....So u shuld certainly look into the PSU oly....there is no other explanation...I
t must ahve overheated because of the load and would have gone down...
Get a gud quality powersupply atleast 400W for the 9800GT...
