Wait for new SSD? +general new build questions, please
Last response: in Storage
Hello! I have questions on various topics at the bottom, please. And any help with my build is appreciated.
CPU
$210 Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
MOTHERBOARD, which?
$120 GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel Motherboard
$140 GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$160 GIGABYTE GA-P55A-UD3P LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$185 GIGABYTE GA-P55A-UD4P LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard w/ USB 3.0 & SATA 6 Gb/s
$210 GIGABYTE GA-P55A-UD6 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard w/ USB 3.0 & SATA 6 Gb/s
newegg link with gigabyte 1156 ATX boards: http://www.newegg.com/Product/ProductList.aspx?Submit=E...
RAM. want to OC. don't know which speed to get. please see "Which RAM?" question below.
$103 G.SKILL ECO Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBECO
1333, 1.35V, 7-7-7-21-2T, http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$103 G.SKILL ECO Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBECO
1600, 1.35V, 7-8-7-24-2T http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$140 G.SKILL PI 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL6D-4GBPI
1600, 1.6V, 6-8-6-24, http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$103 G.SKILL PIS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model F3-16000CL9D-4GBPIS
2000, 1.65V, 9-9-9-24, http://www.newegg.com/Product/Product.aspx?Item=N82E168...
HARD DRIVE, PRIMARY, which?
$220 Intel X25-M SSDSA2M080G2XX (“OUT OF STOCK”, item N82E16820167027)
$230 Intel X25-M SSDSA2M080G2XXX (newegg says: “Discontinued, replaced by N82E16820167027”)
HARD DRIVE, SECONDARY
$110 Western Digital 1.5TB Caviar Black Model:WD1501FASS
VIDEO CARD. I'm thinking GTX 460. but which?
$230+ so many models on newegg: http://www.newegg.com/Product/ProductList.aspx?Submit=E...(Fermi)
POWER SUPPLY
$110 Corsair 750W PSU Model:CMPSU-750TX
CASE:
$60 Cooler Master 690 Mid Tower ATX case Model:RC-690-KKN1-GP
OPERATING SYSTEM
XP 32 bit (already own)
HEATSINK/FAN:
$35? ?????
Total, with cheapest choice for each: $1198
Questions:
1. Which motherboard? Gigabyte suggestions only, please. I am interested in overclocking.
Do the more expensive motherboards offer my build any advantage, overclocking or otherwise? OTherwise I'll just go with the cheapest, considering combo deals.
Will the USB 3.0 or Sata 3.0 matter at all for my build?
2. Which RAM? G.skill only, please. I'd like to OC. With an i5/nehalem system, does a faster CPU mean worse RAM timings, and if so, does it make up for worse RAM timings?
If so, I would like as much OC as possible on air cooling. How fast speed should I get? How will I know if the RAM is plug and play? I don't really wanna pay more than about $130 for RAM.
Can I still get a fast CPU speed with 1333 or 1600 RAM? Even if all these RAMs recommend 2t command rate, will they all, especially the more expensive ones, be able to get a 1t command rate?
3. Will I have any problems trying to install windows Xp 32 bit with my build? For example, I do not think these mobos have a connection for a floppy drive.
Will I need a floppy with SATA drivers to install XP onto a SATA drive? Would I have to use an external floppy?
4. Are RAM sticks like this with slightly names manufactured exactly the same, except the higher model ones tested better?
e.g. F3-10666CL7D-4GBECO, F3-10666CL8D-4GBECO, F3-12800CL7D-4GBECO. What does the first F in g.skill's ram models stand for?
5. Is the newer SSD worth waiting like a week+ for? Does anyone know any specific differences between SSDSA2MH080G2C1 / SSDSA2MH080G2R5 and the newer SSDSA2M080G2GC / SSDSA2M080G2GN?
6. Which video card and heatsink/fan should I get?
7. To any overclockers out there, how often does your computer crash? Does firefox crash more with an unstable OC? And is it possible to get a high OC and never fail prime95?
8. If I want to upgrade an LGA 775 build to 1156, could I just format x25m SSD HD(after plugging it into another computer),
swap in a mobo and cpu, and reinstall Windows? Would I run into any problems?
9. Has anyone here ever used a RAMdisk to make use of more than 4 gigs of RAM on a 32 bit OS?
Anyone know a good place to look for info about that?
10. Does anyone have any links to sites that show windows xp significantly beating windows 7 in benchmarks?
11. Is 1 stick of 4 gigs more likely to fail than 2 sticks of 2gb?
12. I'm thinking about a getting a laptop for word processing. Is a $400 new laptop off newegg worth spending more on than a $100-200 dollar one off of ebay?
13. Should I look into getting parts from any other website besides newegg? I live in the US.
14. Anyone here ever gotten recertified or open box stuff off newegg? Anyone ever gotten new PC parts off ebay?
15. I heard Intel makes makes all the CPUs the same, then makes them worse for lower models. Why do they do that?
16. If you got a gigabyte board, and RAM slots 1 and 3 didnt work, and a lot of people were complaining about that problem, but RAM slots 2 and 4 did, and it overclocked stable, would you return/refund the board or just keep it?
There are a great many questions, most of which don't apply to the storage forum. Also...
r_manic said:
Tom's Hardware Rules of Conduct
Don't...
  • Bump posts, claim "first!"
  • 1. Will the USB 3.0 or Sata 3.0 matter at all for my build?
    Depends. Do you want to future proof? Otherwise, no.
    3. Will I have any problems trying to install windows Xp 32 bit with my build? For example, I do not think these mobos have a connection for a floppy drive. Will I need a floppy with SATA drivers to install XP onto a SATA drive? Would I have to use an external floppy?
    With SSDs you want Windows 7 for trim support. There's also little reason not to get 64bit, like Tom Thumb said above.
    There is always something newer around the corner, you could keep waiting forever for the next best thing. What 'newer SSD' are you referring to, by the way? As for those model differences, google can help you there.
    Yes you could. No you wouldn't - at least no problems you wouldn't otherwise have anyway.
    Basic math. There's only 1 stick so there's half the chance of a stick failing than with 2 sticks. On the other hand you can keep working if you have 2 sticks and one fails. Solution: 2 sticks of 4gb ;)
    All is an overstatement, but when they do things like this they do it for profit.
    If there was ample proof - as in not just your average amount of unlucky people - I wouldn't get it in the first place. But hey, that's really up to you isn't it.
  • Ask the community
