Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will my 650W power supply be enough for this....
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will my 650W power supply be enough for this....
I have an Antec NeoPower 650. It has been running well with a Phenom X4 9950, 8 gigs of ddr2 800 ram, a radeon 4870, and a single 320 gig hard drive ( I really have no need for more than that but I want more). I am looking to upgrade my system, but I don't know much about power supplies. Will this power supply be enough for an i7 920 OC'd to 3.2 ghz, a 1TB hdd, radeon 4870, 6 gigs ddr3 1600, cooler master haf 932 case, and cooler master v8 heatsink? I would appreciate any help or non-biased opinions.
Sponsored Links
Try this:
"eXtreme Power Supply Calculator - Lite version"
http://www.extreme.outervision.com/psucalculator.jsp
Reply to Pekk@
The power consumption won't be significantly different from your current system.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
Well yes that PSU is a very good quality PSU if not the best...And for the setup that you want to get, even a 550W PSU would be suffice...So that 650W can easily handle that setup...
But just a heads up...it would not be able to run 2 4870s in crossfire...
Reply to gkay09
Thanks for the help everyone. I appreciate the feedback.
gkay - I kind of figured it wouldn't be able to handle crossfire. My plan is when I do decide to get another graphics card to upgrade the PSU with it.
Thanks again guys.
Reply to rgglass84
^ Then no problem at all...
But that PSU can easily run 2 4850s in crossfire though...
Reply to gkay09
I like my 4870 too much to get rid of it though :)
Reply to rgglass84
Agreed. plenty of power for your proposed setup.
Reply to mi1ez
Haha...no one said you to part away from that :P
I was just giving a rough idea what your PSU could handle... :)
Message edited by gkay09 on 05-12-2009 at 10:45:56 AM
Reply to gkay09
Have that exact same build except two HDD's totaling 1TB and a GTX 260-216 on a 550W Antec PS. You can put anything you want on that power supply outside of SLI with no problem.
Reply to chripuck
There are 660 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
