I'm, getting a Chassis Intruded error on my ASUS P5Q Pro. What is this, what is the fix?
jeep11 Distinguished Oct 26, 2008 107 0 18,680 Feb 13, 2009 #1 I'm, getting a Chassis Intruded error on my ASUS P5Q Pro. What is this, what is the fix?
shortstuff_mt Glorious Apr 1, 2008 10,191 24 43,965 Feb 13, 2009 #2 You can reset the chassis intrusion switch in the BIOS. The motherboard owners manual should tell you how to do it.
jeep11 Distinguished Oct 26, 2008 107 0 18,680 Feb 13, 2009 #3 In the POST it says FATAL ERROR... System Shut down. How do I get into the BIOS from There.
shortstuff_mt Glorious Apr 1, 2008 10,191 24 43,965 Feb 13, 2009 #4 How far are you into the post process when you get that error? You should be able to press the "Delete" key at initial boot to enter the BIOS.
doormatderek Distinguished Jun 1, 2006 417 0 18,790 Feb 13, 2009 #6 Just look at the ALL, and disable that option
