Tom's Hardware > Forum > CPU & Components > CPUs > FSB speed vs memory speed
Many new laptops come with 1066MHz FSB but have DDR2 memory with 800MHz. Can the laptop be upgraded to DDR3 memory and will it make a noticable difference?
Sponsored Links
You can't upgrade to DDR3 unless you buy a new laptop. You need benchmarks to measure the difference.
Reply to GhislainG
Which laptop are you talking about?
There really isn't something called DDR2-1066 RAM. Meaning there are no JEDEC standards for the stuff. What there is is DDR2-800 RAM that's been tested to run at the higher speed, generally with relaxed timings.
Reply to jsc
There are 1244 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
