Sign-in / Sign-up
~~~~Need advice for New Build~~~~~~Thanks
  • New Build
  • Systems
Last response: in Systems
February 13, 2009 5:12:37 PM
I am building a new computer to last like more than 5 years and will add another gtx 260 to make into an SLI maybe two years later to make my build last longer. I need advice on the parts please,if you have any advice to make it better please reply~~ Thanks
CPU: Intel Core i7
Mother board: EVGA X58 3X SLI
memory: Aeneon Xtune AXH760UD10-18J-K-2G
http://www.ncix.com/products/index.php?sku=36115&vpn=eV...
Video Card: EVGA E-GEFORCE GTX 260 Core 216 55NM 576MHZ 896MB 1.998GHZ
Hard Drive: Seagate Barracuda 7200.11 1TB Hard Drive
Case: Antec Nine Hundred Mid Tower Gamer Case 900 ATX 9 Drive Bay No PS Top USB2.0 1394 Audio
http://www.ncix.com/products/index.php?sku=21123&vpn=NI...
Power Supply :Corsair TX750W 750-Watt Power Supply - ATX, 140mm Fan, SLI-Ready, SATA-Ready, 80Plus
More about : advice build
February 13, 2009 5:49:18 PM
wow that is one hell of a deal for mobo and ram.
I wouldn't get that drive, Seagates have problems. Look at the WD Caviar Black 640gb or the 1TB if you can afford it, they are very reliable and fast.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
You could go with a 650tx for that system, 750w isn't necessary. If you wanted to SLI later, then I would look at a 850w PSU like the 850tx. If you don't care about the color of the PSU, you could get a 750w PCP&C for the same price as the 650tx. A 750w PSU would work, but you would be running it at lower efficiency and have less headroom.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
That is a good case, Look at the CM 690 for a cheaper solution, its wider than the 900 so you can fit a bigger CPU cooler and has excellent cooling.
February 13, 2009 5:53:59 PM
thanks for the advice it's really useful
February 13, 2009 10:16:16 PM
anyone with more advice???
