Sign-in / Sign-up
Solved
I7-930 overclocked power consumption
  • CPUs
  • Power Consumption
  • Intel i7
  • Power
  • Overclocking
August 28, 2010 2:20:27 PM
the i7 line has a peak load of 130W when at stock speeds. How much power does a 930 consume at various clocks... Let's say 3.0, 3.2, 3.4, 3.6 etc...
Does it scale linearly?
I ask this because I plan to do a very mild overclock, but I can only use the 4-pin power which has a capacity of 150 Watts.
Also, does the power cable have a safety margin?
More about : 930 overclocked power consumption
September 6, 2010 9:13:04 PM
I have noticed that when I have turbo mode turned off the peak load is 130 but when I have it turned on it is around 148.
What's up with that?
m
l
a b à CPUs
a b K Overclocking
September 7, 2010 1:19:39 AM
Power consumption goes up linearish if you keep default voltage, however for high OCes or voltage increases it goes up much faster than linear.
m
l
a b à CPUs
a b K Overclocking
September 7, 2010 1:22:36 AM
Also, if you want to keep a close eye on power consumption, get a Kill-A-Watt meter (or other power meter). It will give full system power, but from that you can find increases.
m
l
September 14, 2010 12:34:13 AM
So.... speed is proportional to current, and since power = current * voltage, if I increase voltage by 10% and speed by 10%, power draw will increase by 21%
Right?
m
l
September 17, 2010 3:23:58 PM
Best answer selected by tom thumb.
m
l
