Tom's Hardware > Forum > CPU & Components > Other Components > Problem finding drives
i am trying to find a CD/DVD burner that will work with my motherboard the only problem is that it comes with a SATA wire and a power plug when i put SATA into newegg and tigerdirect it only came up with versions of the CD/DVD drive with just the SATA wire. someone plz help it will be appreciated thank you
Sponsored Links
Can you explain what you mean by "the only problem is that it comes with a SATA wire and a power plug"?
Reply to GhislainG
appartenly there are two different kinds of sata cables one is the power and information and on is just for information, my motherboard doesnt support a ribbion cable but the power plug is a 4 prong insert, i cant find one with the sata wire and the 4 pronged plug
Reply to jameses2007
What motherboard do you have? Does your PSU have SATA power connectors? If not, then you need a cable like this: http://www.pccables.com/01619.htm. You could also use a cable like http://www.cooldrives.com/seatacapoand.html.
If your PSU provides a SATA power cable, then all you need is a SATA data cable that meets your requirements: http://www.cooldrives.com/sa7pinca28wi.html, http://www.cooldrives.com/seatasalacau.html or whatver cable type you prefer (angled at both ends, only at one end or no angles).
Reply to GhislainG
thank you very much man as always if i post on toms hardware i usally get the best responses thank you again
There are 1320 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
