Tom's Hardware > Forum > General Networking > Network General Discussions > Using a wireless connection and a wired connection simultaneously
Forum General Networking : Network General Discussions - Using a wireless connection and a wired connection simultaneously
Hi guys,
I'd like to know how I can use my wireless connection (to my ADSL router) at the same time as my wired connection (to a hub, also connected to another PC).
At the moment I can only use one or the other, which is a bit of a pain.
The only thing I need my wired connection for is to transfer large files between PCs - it isn't needed for Internet access or anything else.
What is the best way to set this up?
Sponsored Links
Are both pcs on the same network?
You could disable the wireless when you need to transfer and then re-enable it.
Why not just use the wired all the time?
------------------------------ I ain't signing nothin
Reply to sturm
There are 1110 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
