Solved
Help with Overclocking, not sure what's wrong..
Alright, whenever I manually set my Ram (G.Skill Eco ddr3-1600) to 1600mhz @ 8-8-8-24 with the CPU stock, the system runs.
But if I OC the cpu at all with those timings, (I've tried up to 1.4250v or so) it won't work.
I did the OC Utility thing and it automatically OC'ed my system to...
Cpu: ~3470mhz
Ram: ~1444mhz @ 9-9-9-24.
How can I get the CPU to run at ~3.4ghz with the ram at ~1600 @ 8-8-8-24?
More about : overclocking wrong
System info: CPU
Phenom II 955 Motherboard
Asus M4A89TD Pro/USB3 Memory
4GB DDR3-1600 (G.Skill Eco) Graphics Card
OC'ed GTX 470
Hard Drive
320 gig 7200rpm Sound Card
Fatal1ty Professional Titanium Series Power Supply
Antec LZG-1000 Case
Antec Twelve Hundred
CPU cooling
Mugen 2 GPU cooling
VF-3000N OS
Vista Ultimate 64
CPUs Master
Overclocking Expert
Set your ram to 'normal' settings,
Overclock your chip first and get that stable,
then get onto clocking the ram,
Sorry for short answer but I are tired and need sleep :)
Moto
CPUs Master
Overclocking Expert
If you set the RAM to 1600MHz then increase the CPU Frequency the RAM goes over 1600MHz, you can increase the CPU multiplier without it changing the RAM though. So if you want to increase the CPU multiplier drop the RAM to 1333 1st.
Related ressources
Best solution
CPUs Master
Overclocking Expert
Increase the CPU multiplier not the frequency. The processor at stock is 16 multiplier X 200 frequency = 3.2, as you have a black edition processor you can increase either or both the frequency and the multiplier. The frequency increases the processor, RAM and the NB while the multiplier only overclocks the CPU. So to get 3.4 from the processor set the multiplier to 17 with the frequency at the stock 200, 17 X 200 = 3400MHz = 3.4GHz.
Can I ask a similar question? I have anm X2 5000+ processor (Windsor) and my new Gigabyte mobo lets me increase the multiplier as well as the frequency.
Can I still do this even though it isn't a Black edition?
Ask the community
