Tom's Hardware > Forum > CPU & Components > Other Components > Troubleshoot hardware problem
Forum CPU & Components : Other Components - Troubleshoot hardware problem
Hi,
This is my first post, and hope my english is clear enough.
I have a pc having some problems. I am not gonna enter in big details to simplify this, but I strongly believe it has some hardware problem.
After booting makes auto restart, with safe mode options. I format it and reinstall windows but some days after comes back to auto-restarts. As long as I can see theres no Virus nor software problems.
I am a zero in hardware problems troubleshooting, the only thing I can do is to replace components and see results, but I dont have similar hardware to test.
So my question is, how can I check and find possible mal.function hw components in the PC? Any tips?
thanks
Sponsored Links
Hi webrp, welcome!
Well you can try two things: Resetting your motherboard's CMOS, and testing your memory for errors. Your mobo manual should have information on how to reset the CMOS, and you can use a tool like Memtest86 to test your memory.
Hopefully this helps, and good luck! Let us know what happens.
Reply to r_manic
There are 395 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
