7900GT Problem
Forum Graphic & Displays : Nvidia - 7900GT Problem
Ive got an old crappy computer that had an ATI X600 Pro. A pal gave me his 7900GT to plug in its place.
Now after about 30 seconds of playing CoD4 the game locks up - but if I open up the task manager and close the game comes back to life for another 30 seconds or so. This cycle never ends.
Ive got the latest Nvidia driver installed. I do sometimes see funny shaded pixels. I have not over clocked the card myself. Is this an idicator of a bad card thats been beat on or something else?
I open to all suggestions - even if I have to blow up the card - since it was free anyways.
Sponsored Links
Are the temps OK?
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
- 0 +
Sounds like a driver conflict but could also be heat related or power supply. Did you use a driver cleaner before installing the new drivers? How about a fresh install of Windows. How about +12v rail amperage? I as I remember the 7900GT requires a mimimum of 20a on the +12v rail.
Edit: If you haven't done so use Rivatuner to increase your fan speed and see if that solves the problem. Download GPU-Z and record your temps while playing.
Message edited by Craxbax on 03-11-2009 at 10:45:25 PM
Reply to Craxbax
- 0 +
does that new video card need external power supplied to it? check and see if it has a plug on the end of the card for power
------------------------------ qx9750(not a typo)
Coolermaster Gemini2
MsiHD4870 1gb
4gbDDR2
Reply to sontan
Have you tried using older drivers, 84.xx's?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
If what sontan said doesn't work ask your friend if he has had the same issues.
The 7 series cards were notorious for bad ram chips and artifacts.
Try some other games to see if the problems show up too, CoD4 might be a little rough for that card.
Reply to ravenware
Tom's Hardware > Forum > Graphic & Displays > Nvidia > 7900GT Problem
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
