Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drives - OEM
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Ok Upon building of this new machine, I have came across so many BSOD it let me down, And made me think about buying a whole new setup or just buy a built one and replace the graphics card.
Now it wont even post the BSOD, Vista just tells me I recovered from a BSOD.
So heres the problem.
Problem #1. I cannot install all 4 Ram sticks, I have 2 In the Yellow slots, When I put 1 in the Black slot it freezes about 5-10Mins after OS Loads, If I put 2 In the black slots it wont post or Bios at all.
Problem #2. I got it to run with 4Gbs of ram, 2 In Yellow slots. But while playing games it will restart randomly or lock up. And on World Of Warcraft, It will give me a Error close and sometimes Error and Restart.
I installed all the latest drivers from ASUS and ATI. I didnt Update my Bios or Overclock just incase I need to RMA or Return.
I would try a different power supply first. Rosewill isn't the greatest. Your board is so new that there are no new bios versions yet. You may have to email asus tech support for suggestions on memory. I would try a different brand, such as crucial or corsair.
if it helps, check that u have the latest service pack so it would support more ram.check the mem frequencies.u can check and make sure that there are not BIOS updates.you might have to set the voltage on bios.?
I have almost the same setup, but with ThermalTake TR2 RX 550W and a xfx 4870, but you han only put two sticks of ram, try one in A1 and the other in B2.
By the way I am also getting random freezes, so if you solve your problem please contact me at shnere at gmail
