Tom's Hardware > Forum > Graphic & Displays > Nvidia > Annoying Problem
Annoying Problem
Forum Graphic & Displays : Nvidia - Annoying Problem
Ok this is my problem, I have a Samsung SyncMaster T220, and the monitor turn off for no reason at all, the main problem is that when this happends I can't do anything I have to wait like 3 to 5 minutes so the monitor can turn on again automaticaly, this is really an annoying problem, I would like to know if someone had this problem to.
thxs.
btw using nvidia 9500 card.
Message edited by K4mU1 on 03-12-2009 at 04:25:24 PM
Sponsored Links
Check your connections including how the graphics card is seated in ur pc. If not then u most probably have a faulty monitor
------------------------------ Mobo:Asrock K10N780SLIX3-WiFi Processor:AMD Phenom II 940 RAM:4Gb Ballistix Tracer Graphics Card: Inno3d GTX260
Add me on xfire: rav3n52
Reply to rav3n
- 0 +
no this is stander due the power saving of the screen its self i have the same and it takes a 1 mins to boot up from standby. try testing it with a different input
Reply to jagzc
I have the same monitor, the same video card AND THE SAME PROBLEM.
Looks like its something about the way the on/off switch works.
I have already returned the monitor and got a new one, but the problem persists. And it not happened on the store (after 40 minutes connected at a store's PC), and my old Samsung monitor (an LCD 19" one) works OK too.
Mistery...
I will just sell this and buy another with regular switch.
Reply to mfioroni
I have the same problem but under diffrent hardware (gtx275 & 2408wfp). It only occurs with the new 185 & 186 drivers, try using the older 182 drivers and see if it fixs it. It worked for me.
Reply to LordOfTheGeeks
There are 687 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
